    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-26-2012, 04:37 PM   #2881
offroad dude's Avatar
Trader Rating: 25 (100%+)
Originally Posted by t8rtot View Post
stop shopping on Amain.. go back a page or two and see why..
as a matter of fact..
http://www.speedtechhobbies.com/inde...roduct_id=1958
http://www.amainhobbies.com/advanced...XGS013&x=0&y=0
man i have too much free time..
With saving like that, it makes up for the free Amain shipping on parts-...WoW
offroad dude is offline   Reply With Quote
Old 11-26-2012, 05:16 PM   #2882
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Cpt.America View Post
Too many other variables. Track was blown out... tires weren't as broken in... who knows. It wasn't because he moved from RM to MM though. The track appears to be no more than a medium bite type track where a RM balance will give a noticeable advantage.
Actually you're the same reason you think RM would help is why MM is helping him. Like he said the pendulum effect is causing a large amount of weight transfer on a medium traction track where (in stock buggy) MM allows him to come into the corner faster and carry that speed thru the turn and because of this, on exit, he's driving faster than traction available causing him to step out. In mod this may cause an issue, but not with a 17.5...
To say it was everything else but MM and to completely discredit it for no other reason but it's not the norm is very disappointing coming from you. Especially since you're an integral part of this thread and this forum. I figured you'd be more open minded even more so with all the cars you've owned.
There may be other factors, but mid motor from a design aspect continues to be faster when set up and designed correctly. I'm a believer, once the money is spent to really making it main stream and the technology catches up...just remember I told you so. But for now, the tires don't have the traction in mod
Sfida
t8rtot is offline   Reply With Quote
Old 11-26-2012, 05:24 PM   #2883
t8rtot's Avatar
Im just tired of amain raping on price and shipping, I still order some stuff from them but don't be brainwashed into thinking their the only ones with a selection.
You took the time going with a car that is different from the rest to get an edge, and definately not the cheapest option, why not give you're wallet a break now..
Sfida
Old 11-26-2012, 05:25 PM   #2884
I have a quick question. I'm building my shocks and the manual states to put on the medium O-rings on the bottom of the shock bodies. However, those O-rings are too big. Now the small O-rings will work but they are not called out in the manual. Should I just use the small ones and not the medium ones..?
Old 11-26-2012, 05:29 PM   #2885
Never mind I figured it out duh....
Old 11-26-2012, 05:31 PM   #2886
aloksatoor's Avatar
Trader Rating: 42 (100%+)
x2 on that. I buy speedtech and absolute as far as possible.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 11-26-2012, 07:03 PM   #2887
aloksatoor's Avatar
Back to work is exotek doing some red hubs to go with the nice new shock standoffs?
Old 11-26-2012, 07:50 PM   #2888
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Sorry to disappoint you.. but frankly, im not here to impress you. I just give my opinions like everybody else, you are free to listen to them, or ignore them... matters not to me. But im only here to help.
Iv owned and raced both mid motor cars, and rear motor cars, but only on the tracks local to me here, and lap times always favor the car that has more weight over the drive tires. It's a combination of having only medium levels of traction at hand, and the tight nature of the smaller indoor tracks.
At BRCR we used to run our clay wet. We would mist the track every hour to keep it tacky, and we ran slicks. Our traction level was at or above carpet. Mid motor cars were tops! I ran the Schumacher Couger then, and nobody could touch it. It carried more corner speed, and because traction was SO high, I could get heavy on the throttle on 180s and have plenty of rear grip (no wheel spin). About a year into our clay, we decided to start running our clay like all the other tracks in the area, dry. We would still water at the end of the night, but the clay hardned up over night and through the day (like most tracks) and we ran pinned tires (gold barcodes). Traction was still good, but nothing like the bizzare carpet like traction of the wet clay we used to run. Now that traction level was down to around "medium"... the mid motor cars just couldn't get on the throttle hard enough in some sections of the track. So while they might of been better in the sweeper and some of the faster sections, they were MUCH slower on the 180s and tighter turns where you needed a lot of rear/forward traction. You would spin a bit and lose your momentum, and all of a sudden, all of the time you made up in the fast sections, was gone. Overall laptimes were lower because the car became less consistent. I spent a LOT of time working on setup, and you just can't "out setup" having a lack of weight over the drive tires when traction is low.
Even drivers like Jorn, who is a master of the mid motor car, one of the fastest guys on the planet, ran RM here in the states on our smaller indoor clay tracks in his durango... Why? because it produces faster lap times with that level and type of traction.
Look, im not saying that mid motor can't work with the proper set up. But there is always a give and take with how you run the weight balance and location in a car, and with a lower traction surface, the time you lose from lack on forward traction is greater than the time gained from extra corner speed on the faster sections of the track. If the car was 4wd or front wheel drive, it would be different... but because the car is TWO wheel drive, and they are in the back, RM will produce better traction OVERALL, than MM. (on our surfaces).
So.. that's my opinion, and lap times back me up. Feel free to run MM, or RM, or whatever you want. Here is where we discuss our opinions, and im not disappointed in you for giving yours.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-26-2012, 07:58 PM   #2889
aloksatoor's Avatar
all the o rings are the same size for me.
Old 11-26-2012, 09:02 PM   #2890
Trader Rating: 27 (100%+)
Would anyone have or know of someone with a extra set of wide blue aluminum suspension holders? I need some but cant find the RR in stock anywhere. Please PM me if you know of any.
Kyosho, Lunsford Racing, Express Motorsports, Dibrino Designs.
C_Money is offline   Reply With Quote
Old 11-26-2012, 09:43 PM   #2891
aloksatoor's Avatar
I could only get mine from japan on ebay. It was cheaper but still slow took like 2 weeks.
Old 11-26-2012, 09:46 PM   #2892
toast.'s Avatar
Trader Rating: 14 (100%+)
Thinking about trying out mid motor just to feel the difference.
My RB6 is built rear motor about how long would it take to convert to mid?
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 11-26-2012, 10:10 PM   #2893
fastestwon's Avatar
Trader Rating: 15 (94%+)
about an hour including rewiring . if you want more info PM me
fastestwon is offline   Reply With Quote
Old 11-26-2012, 10:16 PM   #2894
Who was the eBay seller?
Old 11-26-2012, 10:38 PM   #2895
Johnn27's Avatar
Trader Rating: 71 (100%+)
Questions?? Aluminum rear pivot blocks
Does anyone know if the strc rb5 aluminum pivot blocks will fit the RB6 and if they are narrow or wide ??
Johnn27 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
