    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 11-26-2012, 11:07 AM   #2851
Trader Rating: 36 (100%+)
Originally Posted by sipaboy View Post
I'm going to order an alloy replacement for the RF2 part. The part that breaks all the time in my case. It's the rear hinge pin holder[front side]. I don't want to order the wrong part since they go for $30 each. Can anyone advise me which to order. I'm goingto order afew things at Amain anyways. Thanks to all
The correct aluminum version is "wide". Make sure to order the "outer" one also. I broke one this past weekend.
KYOUMW515GM is the "wide" outer/rear
KYOUMW514GM is the "wide" inner/front
"GM: is the gun metal version
Team MIP - JConcepts - Airtronics - REDS Racing - Upgrade RC - Express RC Hobbies http://www.miponline.com/store/index.html http://www.jconcepts.net
http://www.rcidcustom.com/index.html http://www.expressrchobbies.com
MIP Pro4mance SCTE 2.0 | SC10.2 FT | T4.2 FT
Jonathan Paulk is offline   Reply With Quote
Old 11-26-2012, 11:35 AM   #2852
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Kraig View Post
You probably will have to clean it frequently if you are getting dust on it. I bought a sc from someone and they had the Durango boots on the outdrives. That boot obviously protected the joint from getting dirt in it.
You could try the bike chain lube too.
hhmm... my mind is now moving.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-26-2012, 11:37 AM   #2853
Super Moderator
edit.
- RCSpecialties -
Old 11-26-2012, 11:48 AM   #2854
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default latest race video still running in mid motor
http://www.youtube.com/watch?v=i-d8vr4ZG8k
fastestwon is offline   Reply With Quote
Old 11-26-2012, 11:49 AM   #2855
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
I was working on my electronics this weekend and came up with these to mount the capacitor and receiver.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 11-26-2012, 11:53 AM   #2856
Trader Rating: 139 (100%+)
Originally Posted by fastestwon View Post
I noticed it having some of that annoying mid motor kick out on power in turns.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 11-26-2012, 11:57 AM   #2857
Super Moderator
andy.. good idea. But just so you know, my receiver mounted/servo taped up perfectly on the side pod with 0 modifications. I just used a little 2 or 3mm strip on the bottom, and a 2 or 3mm strip on the SIDE of the receiver, and it is mounted as strong as any receiver I have ever mounted to a flat chassis. You can see the side servo tape in this crappy picture here.
- RCSpecialties -
Old 11-26-2012, 12:01 PM   #2858
Super Moderator
Car looks 'ok'... but would still be considerably better in RM on that track.
- RCSpecialties -
Old 11-26-2012, 12:10 PM   #2859
fastestwon's Avatar
it does that because it transitions very fast. it is not lazy at all . i can live with it . this coming weekend two more RB6s will be there both running straight up tebo setups .
i am still making small adjustments
Old 11-26-2012, 12:10 PM   #2860
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Was that the leading car? Seems like it needs a bit of drag brake, she was nose up on almost all jumps as well...
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 11-26-2012, 12:13 PM   #2861
lbckevin's Avatar
Trader Rating: 91 (99%+)
fast...
Are you guys running stock 17.5 ? The track is cool that they change it every week. That is alot of work.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 11-26-2012, 12:19 PM   #2862
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by Cpt.America View Post
Would buy... if weren't red.
Psht red is the nest. Red Army!
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 11-26-2012, 12:19 PM   #2863
fastestwon's Avatar
Originally Posted by lbckevin View Post
fast...
they run open mod everything .
i like no timing 13.5 in my RB6 as well as my scr sp .
the track owner likes change so he changes up the layout about every two weeks .
Old 11-26-2012, 12:23 PM   #2864
Super Moderator
You're right.. I might need to make the switch with my bling if they don't start coming out with black or blue aftermarkets!
- RCSpecialties -
Old 11-26-2012, 12:23 PM   #2865
fastestwon's Avatar
that's okay it wasn't upside down either . i don't like drag brakes and i only have 40% brakes total.
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
