    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-25-2012, 04:13 PM   #2821
B00t13g's Avatar
Originally Posted by Bos89 View Post
i ended up just triming into the shock tower works fine and looks good
Any pics?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 11-25-2012, 05:55 PM   #2822
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by K_King View Post
I liked the drilled 55s also. The Losi 55s are actually smaller than drilled 55s.
i noticed that too. the losi 55's are really responsive to oil changes. 2.5 weight is really noticeable where as my drilled 55 where still good but a LITTLE less responsive and a little soft but i'm still playing with my set up.
cnelson3 is offline   Reply With Quote
Old 11-25-2012, 07:26 PM   #2823
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by cnelson3 View Post
For those interested, I tried the 2 hole shock pistons (hand made) and they were awesome. I raced at leisure hours in IL which is a large fast track with big jumps and I switched to losi 55's up front and 1.6 2 holes in the rear for the main. I noticed an immediate difference on the positive side. The car still rolled like it should but also soaked up the hard landings. I'm tempted to try the 2 holes in the front too but I like this set up so well I'm afraid to change it.
I tried 2 hole 1.6 up front today. It was late in the day but it is close. AE BB pistons are the same diameter but about .01" thinner. Just use a .2mm shim and tweak the c-clip a bit and it is snug. I'm doing this until K blanks come in.
Anyway, Made laps with 30wt losi w/pink felt a tad over sprung but not bad. Next was w/32.5 losi before practice shut down and it felt better. Will try AE 32.5 pink and 32.5 losi w/gold springs next. Maybe a starting point for ya to get close.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 11-25-2012, 07:55 PM   #2824
cnelson3's Avatar
Thanks for the info. I will be trying this set up at trackside later this week. I'm anxious to see how this set up works on dirt that is a little less sticky.
Old 11-26-2012, 12:32 AM   #2825
drstrangelove's Avatar
Hi Guys,
I bend my front hinge pin brace due to bad landing and getting a new one. But amian list the following:-
1) KYOUMW519GM - Kyosho SP Front Hinge Pin Brace (Gunmetal)
and
2) KYOUM720 - Kyosho SP Front Suspension Plate (Type-B)
The (1) stated as 1mm thicker. The (2) is the stock RB6 plate. Thinking of getting the (1) since it is 1mm thicker . My question is, will it fit the RB6? Anyone using them?
Another thing, is the front bumper shown below the same as the RB6 front bumper?
http://www.amainhobbies.com/product_...per-Set-RB5-WC
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 11-26-2012, 01:15 AM   #2826
Trader Rating: 27 (100%+)
Originally Posted by drstrangelove View Post
Hi Guys,
and
Look in your Manual it will tell you the exact part numbers you need.
Kyosho, Lunsford Racing, Express Motorsports, Dibrino Designs.
C_Money is offline   Reply With Quote
Old 11-26-2012, 01:19 AM   #2827
toast.'s Avatar
Will the T-Bone RB5 bumper fit?
Anybody think its necessary?
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 11-26-2012, 01:44 AM   #2828
silvalis's Avatar
Trader Rating: 29 (100%+)
I dont see why not. The RB5 bumper screws are the same distance apart.
I guess it depends on what you're hitting, although I'm a bit dubious on whether or not it will save your steering rack...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 11-26-2012, 06:48 AM   #2829
Trader Rating: 91 (100%+)
Hi Guys,
and
No it will not, the distance between the holes is 1mm different.
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 11-26-2012, 06:57 AM   #2830
t8rtot's Avatar
Trader Rating: 14 (94%+)
Hi Guys,
and
since your shopping online, I'd recommend strongly looking for your Kyosho parts on Speedtech. i don't work for them but am a fan of fast shipping and excellent customer service, and better prices.
http://www.speedtechhobbies.com/inde...roduct_id=1818
its only a $2 difference here but compare other aluminum upgrades and there is a huge difference (hubs for instance) take a look...
http://www.speedtechhobbies.com/inde...roduct_id=1832
http://www.amainhobbies.com/advanced...516GM1&x=0&y=0
Sfida
t8rtot is offline   Reply With Quote
Old 11-26-2012, 07:03 AM   #2831
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Amain has 10% off over all orders over $100 today. That makes a RB6 just $404 plus shipping.
StormerHobbies also has the RB6 discounted down to $420 plus shipping.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 11-26-2012, 07:45 AM   #2832
frito's Avatar
Trader Rating: 59 (100%+)
i just ordered from speedtech,shipping is cheaper and most parts are than amain are....thanks for the info ..
rc8b3e
b44.3
bfmce
t5m
radioactive raceway
frito is offline   Reply With Quote
Old 11-26-2012, 07:48 AM   #2833
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-26-2012, 08:10 AM   #2834
t8rtot's Avatar
just trying to keep some additional $$$ in your pockets.
Sfida
Old 11-26-2012, 08:24 AM   #2835
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Eper, come in here and share that setup.
t0p_sh0tta is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
