    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-25-2012, 07:33 AM   #2806
Originally Posted by s.i.jerefos View Post
All I can say is that Exotek ROCKS.
I placed My order of the options for My RB6 and I couldn't believe in My eyes.
I received them in 6 days in Greece via USPS and I was impressed with the quality.
I am making carbon fiber dive equipmentt for 6 years and I can say that I received a high quality ooptionals.
My only problem id that I can't wait to use the mid motor rear tower.
Coould somebody give Me some details about the difference between rear / mid motor usage becsuse thid is My first time with electric off road?
Mid motor would be used for artificial turf/carpet (super high grip) The rear motor is for dirt or clay applications (allows the car to rotate more). That's my understanding ....
ChadBlanton is offline   Reply With Quote
Old 11-25-2012, 08:34 AM   #2807
frito's Avatar
Trader Rating: 59 (100%+)
Guys just ran mine let night for first time , just out of box setup basically with 8.5 on a semi clay dirt surface indoors, was having problems hooking rear up ,like car just wanted slide everywhere under power . Just curious what some where running as setups
rc8b3e
b44.3
bfmce
t5m
radioactive raceway
frito is offline   Reply With Quote
Old 11-25-2012, 09:28 AM   #2808
underway's Avatar
Trader Rating: 48 (100%+)
I went to gold springs in the rear and removed the .5 shim under the rear hingepin holder. Made a world of difference. ALso went to outside hole on inner camber link on rear and outer on hub.
underway is offline   Reply With Quote
Old 11-25-2012, 11:36 AM   #2809
cnelson3's Avatar
Trader Rating: 65 (100%+)
For those interested, I tried the 2 hole shock pistons (hand made) and they were awesome. I raced at leisure hours in IL which is a large fast track with big jumps and I switched to losi 55's up front and 1.6 2 holes in the rear for the main. I noticed an immediate difference on the positive side. The car still rolled like it should but also soaked up the hard landings. I'm tempted to try the 2 holes in the front too but I like this set up so well I'm afraid to change it.
cnelson3 is offline   Reply With Quote
Old 11-25-2012, 12:01 PM   #2810
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I liked the drilled 55s also. The Losi 55s are actually smaller than drilled 55s.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 11-25-2012, 12:08 PM   #2811
Trader Rating: 62 (100%+)
Broke a ballstud in the front bulkhead. The default setup is the ballstud goes on the outer hole. Since the broken ballstud thread was left inside the hole. What will happen if I used the middle hole instead? Of course I have to adjust the turnbuckle to get the camber I want.
sipaboy is offline   Reply With Quote
Old 11-25-2012, 12:23 PM   #2812
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
I moved my front ball stud to the middle position on my car and it helped to get more steering out of my car. Another option would be to use a disc and a dremel to cut a slot in the broken stud, then use a flat head screw driver to get it out.
OnRDPassion is offline   Reply With Quote
Old 11-25-2012, 12:25 PM   #2813
New Kyosho owner here...lol. I just got my RB6 and am trying to fit my Orion R10 Pro speed control into position beneath the rear shock tower. There is a clearance issue with the wires coming out the top of the speedo and into the shock tower base preventing me from placing the speedo in that position. Has anyone else had this problem? It seems like the only option would be to trim a little into the shock tower base. What do you guys think?
Hollywood_26 is offline   Reply With Quote
Old 11-25-2012, 12:27 PM   #2814
cnelson3's Avatar
The front end will get a little slower to react. I tried the middle hole out and it's not bad. Lower ur front camber and it help to increase the initial steering you'll loose.
Old 11-25-2012, 12:30 PM   #2815
i ended up just triming into the shock tower works fine and looks good
Bos89 is offline   Reply With Quote
Old 11-25-2012, 12:40 PM   #2816
I second that I had to do the same thing and it fits perfectly now.
Old 11-25-2012, 12:44 PM   #2817
Is there really supposed to be this much slop where the shock caps attach to the shock tower?? Seems like the plastic "shock balls" or " shock bushings" are too small ...
Old 11-25-2012, 01:05 PM   #2818
Trader Rating: 137 (100%+)
Yes, it was designed to be run that way. Do not force thread down any more or you risk binding on the top. I used aluminum nuts and squashed the bushing to make it more snug and my car ran like crap.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 11-25-2012, 01:06 PM   #2819
Or you can just rewire the speed control with 14 gauge wire like I and many others have done
Old 11-25-2012, 03:59 PM   #2820
B00t13g's Avatar
Every time I've run my rb6 I've changed one thing and it just gets better and better!
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
