Kyosho Ultima RB6 & RB6.6 Car Thread
#2671
Hey All. Just wanted to check in on the RB6. Are you guys having as much luck with it as the RB5? I would like to get one but I run stock 17.5 blinky at my track and some feel the RB6 is too heavy for this class. Any feedback would be greatly appreciated.
#2672
So I really want to use the aluminum battery holddowns for this car but how can you mount them in it?
#2673
"Ducky"
#2675
just wondering can you still use a full size battery pack in mid motor for a rb6 like the dex210?
#2678
Thx man. Been running the 55s front and rear but drilled some 55s from K blanks. I like the 2 hole 1.6 rear with 25wt a little better than the 4 hole and 30wt front with the 55s. I just chamferd each side of a 6 hole K piston, glued it, and drilled the last 2 to a 1.6mm.
#2679
@davespeed
You can, it's perfectly possible. I would recommend saddles though, since you get more front with those (i'm using the full size bat, and i'm changing to saddles), and you get a prettier "deck", i.e., ESC behind the saddles etc...
#2681
#2682
Shurr Speed 17.5's. Geared 72/33. Use Associated Spur and slipper pads. Or wait for Triad system to come out. It should not be long now. I myself not being of their caliber of driver yet, did manage to place 3rd overall in qualifying in Intermediate Stock class this past weekend with an Orion Pro Stock 17.5 (2010 grey can) Motor. Was not slow at all.
#2683
I am going through my car again and i noticed some gear grinding in the gear box. I thought that maybe I was a little heavy on grease on the gears so i pulled it apart and built it again. I then put it together three times now and I still have gear grinding. Has anyone else run into this or have any ideas of what it might be? I also checked the gears and cleaned all of them to make sure there was nothing stuck in the teeth.
#2684
#2685
