    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-14-2012, 09:33 PM   #2596
has anybody tryed the 05 rear hubs for more forward traction?
hollywood7 is offline   Reply With Quote
Old 11-15-2012, 06:09 AM   #2597
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by jwood7 View Post
The reedy 17.5 with the torque rotor is good but I think the new d3.5 with torque rotor is better. End bell all the way up and geared 88/43 motor will run all day at 125 with no fade. Haven't tried the new tekin yet but I've never liked there stuff in the past.
I thought RPM rotors were the ones to go for 17.5?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 11-15-2012, 06:14 AM   #2598
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by fastestwon View Post
did you run it in mid motor or rear motor ?
i ran it in rear motor.
i've ran the reedy and the orion..they are both very smooth.. the orion is so smooth it feels slow, which would make me pull the trigger farther faster which made me personally very in consistant. thats just how it felt to me in 2wd. in 4wd i absolutely love my vst.. i think i just need to take more time and dial it in to what i like in 2wd
hollywood 7.. i am running the .5 hubs in my car, with the stock rear arms and like the feel
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 11-15-2012, 06:15 AM   #2599
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
If you don't need the torque, or need more top end, then yes. I've never been anywhere that I would want to sacrifice low end for more top end (in 17.5).
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 11-15-2012, 07:46 AM   #2600
pekow91's Avatar
Trader Rating: 45 (100%+)
I asked the same thing in the Tekin thread and the guys over there said those motors are better suited for on road cars. You could use it for 2wd buggy but they liked the normal one better.
Anyway, I get my RB6 today! So amped.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 11-15-2012, 08:13 AM   #2601
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yep.. I run a Fantom Apex 17.5 and run the 12.5 High Torque rotor with it. It's a must have for the RB6 as the car is a bit on the porky side. (medium sized indoor clay).
I imagine if you were running on a very large outdoor track (1/8th scale track) with longer straights and fewer turns, you may want the 12.3 broad power band, or 12.3 high rpm... but I don't know anybody that runs 1/10th scale buggies on that type of track.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-15-2012, 10:31 AM   #2602
CanyonCarverR1's Avatar
I prefer the torque for all applications. I can manage RPMs with gearing
CanyonCarverR1 is offline   Reply With Quote
Old 11-15-2012, 11:38 AM   #2603
DeanV's Avatar
[waves hand] we have 2 pretty large tracks here in AZ they they always include long straights....
I run the Novak 17.5 High RPM motor and even on smaller tight tracks it is really good. The key is, you need to gear these like a 13.5 motor. i.e. my usually gearing is 29/69 instead of the 30's needed for a normal 17.5
I had it geared 32/69 when I first got it, and it was a mistake... no acceleration on layouts that have a turn followed by a jump. Re-gearing solved that.
Dean
ARC R11
XRAY T4 VTA
XRAY X12 2016
DeanV is offline   Reply With Quote
Old 11-15-2012, 12:09 PM   #2604
Yeah I did last race weekend...for sure the car was a little better accelerating and more stable while braking...lost some straight line speed but I think also lost some steering going in the corner.
I am going to try and lower the roll center (RF rear suspension blocks) which should give more overall traction...why don't you try that first or softer rear spring?
nitroargi is offline   Reply With Quote
Old 11-15-2012, 12:40 PM   #2605
NTR
Another problem with the stock motors right now is roar, right now two motors that should be on the list of approvals are not (novak high rpm, and the new tekin motor). Then the one motor that should defiantly not be on the list (d3.5) is on the list. Roar is working on a different way to tech and approve the new 17.5 motors, the rules were written a long time ago. So some stuff is a little outdated. Right now they are not approving any new 17.5 motors, which sucks because i love my novak motor and really dont want to run my d3.5. To some people that dont mind if the motor is approved or not, thats fine. But i personally like knowing i can go to any race i want, roar event or not and know that i am allowed to race.
NTR is offline   Reply With Quote
Old 11-15-2012, 12:48 PM   #2606
Super Moderator
What does this have to do with the RB6? and I don't know anything about the D3.5 that should make it non-roar approved. It's a fine motor, but has no advantage over any other modern day 17.5 My fantom revtechs are equally as punchy and fast.
- RCSpecialties -
Old 11-15-2012, 12:54 PM   #2607
pekow91's Avatar
Sorry guys, my fault. Didn't mean to thread jack with motor talk. Lets go back to talking how great the RB6 is.
Old 11-15-2012, 02:22 PM   #2608
silvalis's Avatar
Well it solved something for me at least - get the high torque 12.5 rotor. Toasted my Ion3 a few days ago doing something stupid.
Old 11-15-2012, 03:21 PM   #2609
Applesauce's Avatar
Are the trans bearings in the b5 the same as the b6?
Applesauce is offline   Reply With Quote
Old 11-15-2012, 03:34 PM   #2610
Trader Rating: 101 (99%+)
Yes they are
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
