    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-13-2012, 05:36 PM   #2566
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by pekow91 View Post
I just ordered the Exotek steering rack and I wanted to see if anyone tried their steering crank. Is it worth getting or is the stock one just fine?
I will be installing my crank arms tonight after work
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 11-13-2012, 06:50 PM   #2567
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Yeti AS3 View Post
The K studs are awesome. Just use the mediums in the caster blocks. I have found that using Lunsford (or any that use a hex driver in the center of the ball) in the rear camber block is the way to go. You cant get a stud to go in straight using a nut driver.
Yes.. the K ballstuds are just fine. But regardless, the first upgrade I do on any car I own, including my RB6, is a full titanium ball stud kit from lunsford.
I concur with what was posted previously... the alu steering rack is a must, but the plastic arms/swivels should be just fine. Their lateral strength should be more than adequate. I doubt you will ever see one break. Run whichever of the two (alu or plastic) is lighter. The last thing you need is more weight on this car.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-13-2012, 09:13 PM   #2568
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I have both rack and arms. I prefer the least amount of slop as possible. Plus they look awesome
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 11-13-2012, 09:55 PM   #2569
silvalis's Avatar
Trader Rating: 29 (100%+)
Just curious: Is anyone with the stock rack still breaking theirs? I ran mine half a dozen times in mod (now back to stock) and the original plastic rack is still fine.
What were you hitting in order to break it? And are these spare plastic racks and exotek rack I bought going to sit in a box looking sad like all of the other K spares I bought for my RB5 and never used...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 11-13-2012, 10:11 PM   #2570
Trader Rating: 101 (99%+)
Default Avid Triad Slipper System
I finally got the chance to test the new Avid Triad slipper & top shaft at WCRC. Between yesterday & today, I have run through at least a dozen battery packs or more. I am running an Orion 17.5 VST (Blinky), geared 69/32.
After my 1st battery pack to get gearing & slipper set, I noticed an enormous improvement in acceleration. The slipper did not fade or need to be adjusted/tightened once during the night and it feels awesome from lap one to the end. Jumps that were normally difficult to clear in NT buggy, were soooooo much easier to approach and land clean with on or off power landings.
I switched back to my kit gearbox/slipper for comparisons sake and ran another pack under same track conditions. Lap times were .5 seconds a lap or faster with the Triad and I have already put the Triad back in to stay. It's hard to not sound like some sort of marketing ad, (but in my opinion), it is a real up-grade!
Going to run it more this week and race with it this weekend... Thanks again to K'Dub (Coach), for letting me test it!
Richard
Kyosho Ultima RB6 & RB6.6 Car Thread-dscn7392.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-dscn7393.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-dscn7399.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-dscn7400.jpg
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 11-13-2012, 11:00 PM   #2571
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
How did you get a top shaft already? Thanks for the update. I look foward to running mine.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 11-14-2012, 12:22 AM   #2572
So this is an Avid Kyosho part or one modified from another car?
Any testing in mid config?
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 11-14-2012, 12:29 AM   #2573
Yeti AS3's Avatar
I broke mine running mod and a buddy running stock. We broke in the same spot by turning a bit early into a tube. The RB5 would have just spun around and kept going.
Hot Bodies D413
AE B5m
Old 11-14-2012, 06:31 AM   #2574
eper's Avatar
Trader Rating: 14 (100%+)
i switched to the aluminum ackerman arm 2 weaks ago the same night i did i got hit in the air and nosed into the lander breaking my plastic bellcranks, so i've purchased the aluminum ones to replace them. it broke right where the ackerman bolts through the bell crank which does appear to be a thin area. imo
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 11-14-2012, 06:45 AM   #2575
t8rtot's Avatar
Trader Rating: 14 (94%+)
i ordered the rack but havent installed it.. too be honest, if i don't have to i probably wont if i don't break, especially since my servo would be the only weak link in the chain if i went all aluminum.
i'm curious to see what you guys are hitting..
Sfida
t8rtot is offline   Reply With Quote
Old 11-14-2012, 06:46 AM   #2576
fastestwon's Avatar
Trader Rating: 15 (94%+)
the next part to break would be the steering knuckles and then servo . their has got to be give somewhere since no more servo saver . the only part that i replaced is the ackerman bar to aluminum because it wears out and gets sloppy.
fastestwon is offline   Reply With Quote
Old 11-14-2012, 06:50 AM   #2577
fastestwon's Avatar
t8rtot did you get to try mid motor yet ?
Old 11-14-2012, 06:54 AM   #2578
t8rtot's Avatar
actually i dropped my radio going in to practice MM so i haven't had a chance to run it.. a few life events have happened since so i haven't raced in a couple weeks. should have my new radio on fri. and will give it a run this weekend.
have you made any setup changes?
Sfida
Old 11-14-2012, 06:59 AM   #2579
fastestwon's Avatar
ride height front and rear 24 mm and went to 2mm shims on rear hubs
Old 11-14-2012, 07:10 AM   #2580
fastestwon's Avatar
Default 3 RB6s
their should be three RB6s at the race track this sunday . a guy sent me his RB6 and wanted it changed over to mid motor . he will start with my setup and make changes to suit his driving style if need be . the other guy will be running in rear motor i think running a tebo setup .
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
