    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-12-2012, 06:38 PM   #2536
Has anybody tryed aka wheels or avid on the rear the axel hole seems smaller on the rb6 than on other cars like losi and ae . can i swicth the axle stub and put a bigger one that fit either losi or ae
hollywood7 is offline   Reply With Quote
Old 11-12-2012, 06:43 PM   #2537
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The axle hole on the wheel seems smaller? If so, just open it up a little bit with a reamer or xacto if need be. No need to change axles. In fact, I ream all of my non-kyosho wheels to make the holes bigger.
If the hole in the wheel is to big I wouldn't worry about it because it will become centered on the hex instead.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-12-2012, 06:53 PM   #2538
I ment the the oppiset the wheels have to big of a hole
Old 11-12-2012, 08:30 PM   #2539
Hey buddy I am running his setup but i just changed a few things and its really good.
edlaret is offline   Reply With Quote
Old 11-12-2012, 10:18 PM   #2540
kdub's Avatar
Triad notification list has started:
http://avidrc.com/product/5/accesori...ccesories.html
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 11-12-2012, 10:56 PM   #2541
BranVita's Avatar
Trader Rating: 39 (100%+)
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 11-13-2012, 05:16 AM   #2542
fastestwon's Avatar
Trader Rating: 15 (94%+)
it looks like $48 + shipping . i have two vehicles i would need them for RB6 and scr sp
fastestwon is offline   Reply With Quote
Old 11-13-2012, 05:20 AM   #2543
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
I have a b4.1 kit...jusy need the shaft!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 11-13-2012, 06:26 AM   #2544
Any idea when we may be able to order them?
(on the web page it says "out of stock")
Thanks.
Allen
abinder is offline   Reply With Quote
Old 11-13-2012, 06:32 AM   #2545
Moderator
Posvar's Avatar
That page is just letting people know it is coming very soon.
Old 11-13-2012, 07:04 AM   #2546
drstrangelove's Avatar
Nice race. I notice around 6.10 one of the driver causes the bug in front of him to turtle and he didn't even have the courtesy to stop and let the guy pass him.
Originally Posted by Rasheed View Post
Built my RB6, first time it touched the track was on the practice day for the first race in the big regional series. I had heard from others that the car had a LOT of steering and I like a mellower setup. Track was high traction clay with several sections where traction rolling was a problem, and only 1 big jump. I used the setup suggested in the manual but made a few changes.
4 degree inserts in front hubs (with bulkhead set on 25 for a total of 29 degrees)
white front spring
white rear spring
2 internal limiters in rear shocks.
21mm rear ride height
23mm front ride height
1mm under all upright ballstuds
car was really good, steering was kind of mellow and the rear stayed planted. Against this crowd I would usually be struggling to even make the A. This race I qualified 5th and finished 4th overall. The rear ride height was really low but it seemed to help avoid traction rolls in the sweeper. Here is a video of the A2 main, I start 5th with the orange, yellow, and green body...
+ YouTube Video
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 11-13-2012, 07:22 AM   #2547
The car doesn't seem to much, if any, front droop (built with no limiters, medium shock eyelets) - Is anyone using the longer shock eyelets or unscrewing them to gain a bit more front droop, or finding that more droop is not needed?
I've yet to get the car out on an actual track, so this is just observation on the bench and tooling around the driveway at this point.
negatv1 is offline   Reply With Quote
Old 11-13-2012, 07:32 AM   #2548
t8rtot's Avatar
Trader Rating: 14 (94%+)
i thought the same thing we i built it. apparently the rb5 is the same car doesn't need much and after running mine indoors on a fairly smooth track, it works well.
after i put on the longer eyelets the car seemed lazier and didnt transition as well.
less droop will cause alot of steering which we're tuning out with the 2/4deg caster blocks.
Sfida
t8rtot is offline   Reply With Quote
Old 11-13-2012, 07:47 AM   #2549
Definitely has a lot of steering, I can tell that from just tooling around on the driveway. Suppose will hold off bench tuning until i have time to get to the track.
Is anyone just going with flipping the bukhead/kickup block to 30degrees (29/30 pretty darn close)
Old 11-13-2012, 08:05 AM   #2550
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Were doing a lot more than just adding 4 degrees of caster to help tame the infield steering... the biggest changes are springs and piston/oil changes. The out of the box setup is extremely aggressive.
You can run the suspension hanger backwards (30) and run the 0 inserts, but this will give the car more front kickup, resulting is more off power steering. You can go that route, but you will be making two changes at once: (+5 caster and increased kickup angle).
Nothing wrong with it... it all depends on how you want your buggy to drive. Even though the car has mega steering already, I am planning on moving to 30/0 caster to see how the car does with more kickup.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
