    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-11-2012, 11:27 PM   #2521
Originally Posted by lbckevin View Post
Dias ran the new Triad tonight on his RB6 as well. It worked great for him.
Do you know what stock gearing Dias runs at WCRC with his schurr speed?
flybyublue is offline   Reply With Quote
Old 11-12-2012, 07:06 AM   #2522
DeanV's Avatar
This past Saturday I was able to actually get a good comparison of my RB5WC vs RB6. We are running the KBRL series here in Arizona and this past weekends venue was rained out so the organizer moved it indoors to where we ran RD1 and where I ran my RB5WC to a 1st place finish.
Same exact layout, same track conditions, over a 20 lap average my RB6 picked up 1.1 seconds a lap over the RB5WC.
Qualified 3rd, worked my way up to 1st. 2 bad laps half way through pushed me back to 2nd and 15 seconds behind 1st. The last 6 laps I was charging and finished 1.8 seconds behind 1st. I decided to change the front tires from what I ran in qualifying which was a mistake (they were inconsistent). Should have just used what I qualified with.
Losi 37.5/32.5 and White/Gold was working great. May even try Gold/Gold next weekend on a higher traction indoor track, but I think for me the White/Gold are good.
Dean
ARC R11
XRAY T4 VTA
XRAY X12 2016
DeanV is offline   Reply With Quote
Old 11-12-2012, 07:42 AM   #2523
t8rtot's Avatar
Trader Rating: 14 (94%+)
i was just having this conversation with a friend about stiffer fronts.. thanks for the feedback.
Sfida
t8rtot is offline   Reply With Quote
Old 11-12-2012, 10:53 AM   #2524
Dean
Definitely thanks for the report.
Allen
abinder is offline   Reply With Quote
Old 11-12-2012, 11:18 AM   #2525
is the triad slipper available for the rb6 yet? or is he using the b4 version? can anyone provide a link please?
rcnewb123 is offline   Reply With Quote
Old 11-12-2012, 02:07 PM   #2526
lbckevin's Avatar
Trader Rating: 89 (99%+)
it is almost out...it is still being tested by some of the Kyosho factory drivers.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 11-12-2012, 02:26 PM   #2527
t8rtot's Avatar
the diameter for the top shaft was the only necessary change wasn't it???
hopefully this wont take long..
Sfida
Old 11-12-2012, 02:42 PM   #2528
Rasheed's Avatar
Default race report
Built my RB6, first time it touched the track was on the practice day for the first race in the big regional series. I had heard from others that the car had a LOT of steering and I like a mellower setup. Track was high traction clay with several sections where traction rolling was a problem, and only 1 big jump. I used the setup suggested in the manual but made a few changes.
4 degree inserts in front hubs (with bulkhead set on 25 for a total of 29 degrees)
white front spring
white rear spring
2 internal limiters in rear shocks.
21mm rear ride height
23mm front ride height
1mm under all upright ballstuds
car was really good, steering was kind of mellow and the rear stayed planted. Against this crowd I would usually be struggling to even make the A. This race I qualified 5th and finished 4th overall. The rear ride height was really low but it seemed to help avoid traction rolls in the sweeper. Here is a video of the A2 main, I start 5th with the orange, yellow, and green body...
+ YouTube Video
Derek "The Speed" Rasheed - Sponsored by Kaiser Permanente. Thrive!
davesrctracks.net - a great offroad 1/10th scale track.
Rasheed is offline   Reply With Quote
Old 11-12-2012, 02:58 PM   #2529
t8rtot's Avatar
welcome aboard!
i see you went softer and your car has excessive body roll it appears? any reason as to why you softened the rear that much? i know body roll may have been a concern. just curious.
just seemed the rear was leaning and not rotating as much which is why that purple car is all on you in the corners towards the middle/end of the race
Sfida
Old 11-12-2012, 03:16 PM   #2530
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default race on new track layout
http://www.youtube.com/watch?v=I-TthqKCMRw
fastestwon is offline   Reply With Quote
Old 11-12-2012, 03:21 PM   #2531
Rasheed's Avatar
Originally Posted by t8rtot View Post
welcome aboard!
You are probably right. I didn't have too many practice runs to experiment. I also didn't have gold front springs. With white front and gold rears I thought the car was still a tiny bit loose in the rear and was a little too aggressive steering wise. I have a lot of trouble driving an aggressive car. With the white rears it locked in the rear and tamed the steering a little. Car was probably a little slower but a fair bit easier to drive. Also my car seemed to traction roll in the sweeper a lot less than others, which was a big advantage during the day.
I am not great at setup and I just try a few things and go with what feels best. With the limited time I had this is what I came up with. Maybe I will get some front golds and try gold gold. I was also using 35 weight oil in front and 30 weight in the rear. Maybe I should make the oil heavier?
Old 11-12-2012, 04:41 PM   #2532
Has anyone tried Cody Turner setup? What do you think?
msandman is offline   Reply With Quote
Old 11-12-2012, 04:45 PM   #2533
pekow91's Avatar
Trader Rating: 45 (100%+)
I just picked one of these up this weekend and I wanted to know how this compares to the DEX210. I loved my Rango but sold it because part support was non existent at the near by tracks. I am new to 2wd drive buggy (driven mostly 4x4 short course and 1/8 buggy) and any insight between the two and the kit in general would be great. In the mean time, I am going to catch up on the previous posts on this thread.
pekow91 is offline   Reply With Quote
Old 11-12-2012, 04:59 PM   #2534
underway's Avatar
Trader Rating: 48 (100%+)
What are the must have springs for the RB6, putting my kit together now and do RB6 springs fit on the FS2 SP 4wd car. $20 a pair I sure hope so.
underway is offline   Reply With Quote
Old 11-12-2012, 05:05 PM   #2535
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Nothing like the rango. One of the laziest 2wd buggies out there. This is a whole world apart in build handling everything. As for springs get the gold rears and for front just for tuning maybe white. Most setup sheets are pink front and gold rears.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
