    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 11-09-2012, 10:39 AM   #2491
NTR
Originally Posted by wrightcs77 View Post
Bigger spur and bigger pinion will move the motor further back, increasing rear weight bias and improving traction........in theory.
Basically taking one of the heaviest parts of the car (the motor) and hanging it further behind the rear axle.
I wouldnt determine my gearing based off wanting to move more weight back, i can do that other ways. I would gear for the best combo of temps/speed/torque or acceleration.
Jconcepts makes some really nice spur gears, so if you dont want to run associated spurs or kimbrough ones, i recommend the jconcepts ones over the kyosho spurs but you will need to change slipper pads
NTR is offline   Reply With Quote
Old 11-09-2012, 10:43 AM   #2492
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I only run the jconcepts losi silent spurs with the losi garodiscs and wc slipper. Works like a charm. Used to have the AE pads but they wont work well with K vented plates.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 11-09-2012, 10:52 AM   #2493
Originally Posted by fullsyzz View Post
That's probably a 64 pitch setup.
You're right. I just looked at the "comment" section of the setup sheet.
(one of Jason Dias' setup sheets and I do appreciate him sharing his setup sheets with us)
Originally Posted by NTR View Post
Can you link the setup sheet?
http://www.petitrc.com/setup/kyosho/..._WCRC20121010/
Thanks again for everyone's contribution to this thread.
Allen
abinder is offline   Reply With Quote
Old 11-09-2012, 11:07 AM   #2494
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Proper gearing and motor placement are not mutually exclusive. You can achieve whatever gear ratio you want with just about any motor position. They are apples and oranges. Man, I could go for an apple about now.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-09-2012, 11:09 AM   #2495
Super Moderator
I use Kimbrough spur gears and standard AE pads and they work flawlessly.
- RCSpecialties -
Old 11-09-2012, 11:22 AM   #2496
Does anyone happen to know if Avid is working on a Triad Slipper clutch for the RB6?
Allen
Old 11-09-2012, 11:23 AM   #2497
aloksatoor's Avatar
On the hex ae pads the glaze is just there in a circle on the edges. The losi slipper pads are just that, a ring so I just like it better. Plus they are machined (and I am a sucker for cnced stuff) so a little quieter than the kimboroughs I had. For stock the AE goes a lot lower than the losi options though.
Old 11-09-2012, 11:24 AM   #2498
aloksatoor's Avatar
Allen
Yep I hope they come out by next week. Thats the last I heard on the avid thread from kdub.
Old 11-09-2012, 11:27 AM   #2499
kdub's Avatar
Allen
Yes, it's ready for release in the next week to 10 days. We have a new topshaft that has smaller flats to fit the existing Triad slipper kits. The adjustment nut changes to a 5.5mm hex M3 nut.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 11-09-2012, 12:11 PM   #2500
Thanks for the info!
Allen
Old 11-09-2012, 03:42 PM   #2501
Hey guys, I have been running my rb6 for two weeks and let me tell you after driving a losi for months. I cant tell you how much better it is... I'm still playing with the setup on it but with the help of derek at kyosho usa it getting better... I'm currently running cody tuner hot rod hobbies setup. I was told that it works really good on clay tracks too.
edlaret is offline   Reply With Quote
Old 11-09-2012, 03:45 PM   #2502
oh ya!!!! I was running on the tlr 22 1.6x2hole ae pistons with 30/25 losi oil. I wanted to see if anyone has tried it on the 6 yet.
Old 11-09-2012, 10:14 PM   #2503
I have a question about building the diff. it appears that the diff rings have a flat side and a rounded side. which side should touch the balls?
rcnewb123 is offline   Reply With Quote
Old 11-09-2012, 10:47 PM   #2504
The rounded one...it's in the manual
nitroargi is offline   Reply With Quote
Old 11-10-2012, 06:58 AM   #2505
gelshocker's Avatar
Hey guys those of you using RSx one10, do you use both 1mm and 2mm shin on the servo mounts (it measures 13.8mm so would merit both shims according to manual). Seems kinda tight though, servo won't lay flat. I think just 2mm is enough? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22968 Today 04:05 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
