    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree18Likes
Old 11-07-2012, 10:32 AM   #2431
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by cateye View Post
Hi everyone I need some advise for my RB6 assemble
As I very new to 2wd buggy I would like to know wat is
e different between rear mount & mid mount of e motor
Like which mount is better on wat track or which is better
for loose n less grip track also which battery type is better
stick ,shorty or saddle pack .thank u
Happy R/C
If you are running on a medium traction or loose track, rear motor will yield better lap times. Also, on a very loose track, a heavier car will probably do better as well. I would start with a stick Lipo, and RM.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-07-2012, 11:00 AM   #2432
Thank u sir
cateye is offline   Reply With Quote
Old 11-07-2012, 11:31 AM   #2433
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Brandon has tried just about everything on just about every car and I would take his advice. Sorry for bailing on you Brandon last weekend in Seattle. I ended up not bringing any gear and glad I didn't because I had zero time. Nice weather though! Even saw the sun!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 11-07-2012, 11:47 AM   #2434
Super Moderator
Thanks, and not a problem! That's usually how it is when you travel... I could of brought my wife's RB5 for you to drive though... She has en entire set up. Next time
- RCSpecialties -
Old 11-07-2012, 12:29 PM   #2435
Originally Posted by t8rtot View Post
to be honest, i'd go to the RB6s petit rc page and look at the tips and setups there, that will fill you in and where we are up to the present, and of course reading thru this thread (start about the same time the car became available ) its solid out of the box, has a ton of steering we're dialing out with caster blocks.
Enjoy the build
Thanks!
Allen
abinder is offline   Reply With Quote
Old 11-07-2012, 04:07 PM   #2436
Originally Posted by DR.Vanostrum View Post
koyosho usually makes very good stuff but anyone who has really built one of these and ran one for any length of time will know what i am talking about......
Don't agree at all as David and som other drivers in Sweden is using the gear diff when they drive on carpet just att the durability of the gear diff is so good as carpet tracks is really hard on the diff.
With the gear diff he get more forward traction but little less steering, and he dont need to rebuild the diff so often.
He did the same when driving the RB5 earlier. As i remember the parts for building a gear diff don´t cost so much.
The parts are:
• UM605
• UM610
• UM611
• UM612
• UM613
• ORG45S ( important with the "S" )
Pierre Ronnefalk - The pit guy !
** HB Racing, Team Orion, AKA, Highest RC, RunnerTime, Maugrafix, Runnertime, XTR, Arrowmax, Avid, Amain, Lundsford, VRC, GHEA, NeoBuggy, LiveRC, RedRC **
PiRo is offline   Reply With Quote
Old 11-07-2012, 04:16 PM   #2437
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Yeah for dirt with medium to loose I would hate a gear diff. I love it I can adjust the stock diff feel with just popping a camber link and a flat head screwdriver. For a gear diff changing that out is a pain. I don't get it though how are all TCs fine with ball diffs for carpet? Think the sakura zero is the only one which has gears in it though I might be wrong.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 11-07-2012, 04:21 PM   #2438
offroad dude's Avatar
Trader Rating: 25 (100%+)
I'm about to by a RB6, is there any parts I need to buy extra to mimic Tebo setup or any setup for a indoor clay track?
offroad dude is offline   Reply With Quote
Old 11-07-2012, 04:53 PM   #2439
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Why do you have to pop a camber link off to adjust the diff That's what the hole in the outdrive is for. One of the best features of Kyosho :
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 11-07-2012, 04:56 PM   #2440
jordy-15's Avatar
Trader Rating: 17 (100%+)
you dont need to pop the ball cup off to adjust the diff just get something with a small enough dia to fit into the hole on the left out drive and turn the right wheel clockwise to tighten and anti clockwise to loosen
alot faster end easier
cheers
:: Proline :: XRAY :: Muchmore::HEI ::
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
jordy-15 is offline   Reply With Quote
Old 11-07-2012, 05:34 PM   #2441
aloksatoor's Avatar
Dang I feel like a doofuss. I have a plastic clip thingy in there do I remove that for good? This is awesome to adjust after those painful schumacher diffs.
Old 11-07-2012, 07:40 PM   #2442
Yeti AS3's Avatar
Ya, I have never used that clip.
Hot Bodies D413
AE B5m
Old 11-07-2012, 07:44 PM   #2443
Energyzer's Avatar
Hello guys.
Anyone tried the gunmetal rear hubs? There are 3 types:
-0º
-0.5º
-1º
What does this angle number mean?! Under what conditions does the part work best?
Cheers, Tiago
Energyzer is offline   Reply With Quote
Old 11-07-2012, 08:18 PM   #2444
fullout's Avatar
Send a message via MSN to fullout
Originally Posted by Energyzer View Post
Hello guys.
-0º
-0.5º
-1º
Cheers, Tiago
These numbers refer to the toe in angle. I think you could also run the -0.5 and the -1 in reverse to create toe out.
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 11-07-2012, 09:25 PM   #2445
AZRC4Me's Avatar
Adjusting the Kyosho diff is as dialed as it gets:
http://www.rccaraction.com/blog/2011...ed-tebo-video/
Throw that plastic clip away, and use something like a 1.5 driver through the hole. You may have to rotate the diff cup to get the driver shaft all the way through.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22972 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
