    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-06-2012, 12:38 PM   #2416
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
The only similarity to a 22 is that it has four wheels and is a 1/10 2wd buggy.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 11-06-2012, 01:40 PM   #2417
Trader Rating: 137 (100%+)
+1.... The 22 is a joke out of the box compared to the RB6 out of the box.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 11-06-2012, 06:00 PM   #2418
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Lonestar View Post
Hi guys
what aftermarket / other brands wheels are there for the RB6? Dex2wd, maybe? Would hex'ed B4.1 wheels fit by chance? Sourcing issues with Kyosho parts here sometimes...
thanks
Paul
I've tried Avids. The front hex is too recessed so you'll need to space it out by 1mm (or dremel it down). The rear you'll need a serrated nut for like the other wheels claiming both b4.1/rb5 compatibility.
Additionally, these avids are slightly broader overall, from memory around 1mm inwards on the inner edge and maybe 0.5mm inwards on the outer edge. This means at absolute full compression the wheel will rub the shock eyelet. You can't really space it out either as you won't have enough thread for even a serrated.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 11-06-2012, 06:54 PM   #2419
Damit's Avatar
Trader Rating: 22 (100%+)
Default RB6 all the way
Honestly, the RB6 could be the best handling 2wd car, EVER.
Its simply awesome!
B6d 2wd / B64d 4wd - SJF01 Street Jam F1 - Tamiya Mini v2
Futaba-HW-LRP-Lunsford-Reedy/Associated
South Australian Member: AERCCC #16 and ARCR 9098
Damit is offline   Reply With Quote
Old 11-06-2012, 10:07 PM   #2420
Originally Posted by t8rtot View Post
what surface? and what gear diff?
Carpet surface and Ultimata SC RTR diff.
Pistons from. Ghea
Pierre Ronnefalk - The pit guy !
** HB Racing, Team Orion, AKA, Highest RC, RunnerTime, Maugrafix, Runnertime, XTR, Arrowmax, Avid, Amain, Lundsford, VRC, GHEA, NeoBuggy, LiveRC, RedRC **
PiRo is offline   Reply With Quote
Old 11-06-2012, 10:11 PM   #2421
Originally Posted by DR.Vanostrum View Post
ya but that thing really sucks !!!
What sucks with that ?
Old 11-07-2012, 12:48 AM   #2422
Appreciate if someone can give me some advise here.
If I'm using mid motor, and want to use the aluminum rear suspesnion holder, which one should I use? is it the KYOUMW515GM or the KYOUMW512GM?
What is the other one for?
Same for this, KYOUMW511GM and KYOUMW514GM?
If I'm using rear motor, I guess I should be using KYOUMW511GM and KYOUMW515GM?
If I'm using mid motor, I suppose to use KYOUMW514GM and KYOUMW512GM, is that how it work?
freeteeanyone is offline   Reply With Quote
Old 11-07-2012, 01:40 AM   #2423
jordy-15's Avatar
Trader Rating: 17 (100%+)
Same for this, KYOUMW511GM and KYOUMW514GM ?
the 2 options are sets KYOUMW514GM,KYOUMW515GM wide mount KYOUMW511GM,KYOUMW512GM narrow mount
recommended setups use wide
cheers
:: Proline :: XRAY :: Muchmore::HEI ::
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
jordy-15 is offline   Reply With Quote
Old 11-07-2012, 01:51 AM   #2424
Thank you sir!
But does it make any different if I'm using rear or mid motor setup?
I see that kyshow provide a separate mount for mid.
cheers
Old 11-07-2012, 05:06 AM   #2425
fastestwon's Avatar
Trader Rating: 15 (94%+)
Thank you sir!
yes use the one that comes with the kit or it won't work right . kyosho dose not make a aluminum one for it yet . using the plastic ones i have not had a problem yet .RF2 mounts for mid
fastestwon is offline   Reply With Quote
Old 11-07-2012, 08:21 AM   #2426
Okay, I'm thinking of picking up a RB6 in the next couple of weeks.
(Currently, my only vehicle is the Losi 22T.)
I'm thinking of using a 17.5 SchuurSpeed motor and Orion Pro ESC in it as well. Any thoughts on the combination or other advice on things for the RB6?
(I have a 17.5 SchuurSpeed and Tekin RS ESC in my 22T; the SchuurSpeed seems to be a great motor in the 22T.)
Thanks for any info or suggestions.
Allen
abinder is offline   Reply With Quote
Old 11-07-2012, 08:24 AM   #2427
NTR
I run the RF block in mid motor, but i run on dirt, i found i could drive the car more aggressively out of the corner
NTR is offline   Reply With Quote
Old 11-07-2012, 08:42 AM   #2428
t8rtot's Avatar
Trader Rating: 14 (94%+)
Allen
to be honest, i'd go to the RB6s petit rc page and look at the tips and setups there, that will fill you in and where we are up to the present, and of course reading thru this thread (start about the same time the car became available ) its solid out of the box, has a ton of steering we're dialing out with caster blocks.
Enjoy the build
Sfida
t8rtot is offline   Reply With Quote
Old 11-07-2012, 08:51 AM   #2429
Trader Rating: 39 (100%+)
koyosho usually makes very good stuff but anyone who has really built one of these and ran one for any length of time will know what i am talking about......
DR.Vanostrum is offline   Reply With Quote
Old 11-07-2012, 10:13 AM   #2430
Hi everyone I need some advise for my RB6 assemble
As I very new to 2wd buggy I would like to know wat is
e different between rear mount & mid mount of e motor
Like which mount is better on wat track or which is better
for loose n less grip track also which battery type is better
stick ,shorty or saddle pack .thank u
Happy R/C
cateye is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Kkrazy
