    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 10-31-2012, 11:56 AM   #2266
NTR
Originally Posted by Johnn27 View Post
Can someone explain how the wider suspension nholder change the cars performance versus the narrow holders and are you guys using the new arm or have you gone back to the older WC arm?
Making the car more narrow causes you to loose rear stability. Also i have gone to the old wc arms, and so has tebo. He says it lets you drive the car more aggressively into the corners. He also said that 95% of people will like the new a arms better. Its just his diving style.
NTR is offline   Reply With Quote
Old 10-31-2012, 12:00 PM   #2267
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
The wider hangers will raise the roll center of the rear of the car, reducing rear traction in the corners. This gives more steering, and less rear traction.
The narrow hangers lower the roll center of the rear of the car, increasing rear traction in the corners. This gives less steering, and more rear traction.
I am running the narrow hangers.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-31-2012, 12:00 PM   #2268
Johnn27's Avatar
Trader Rating: 72 (100%+)
Thanks!
Johnn27 is offline   Reply With Quote
Old 10-31-2012, 01:09 PM   #2269
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
May try this. What's traction like at your track? Did you do this to reduce steering, gain rear bite or both?
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 10-31-2012, 01:37 PM   #2270
Super Moderator
Traction at my track.. for clay.. is very high. Not as high as say the turf tracks in europe, but traction rolling can happen in some sections if not careful. Wheelies? no problem.
I moved back to the narrow hangers because I find the car (at least at my track, with our traction levels), has an unREAL amount of steering. The car is very very aggressive. The more aggressive a car is, the more room you have when shifting traction to the rear of the car. Running the narrow hangers lets me push the car very hard because it helps keep the rear end in check diving in to, and accelerating out of the corners. It was a tuning aid to help calm the car down.
- RCSpecialties -
Old 10-31-2012, 01:50 PM   #2271
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by aloksatoor View Post
hoping exotek comes up with something like they got for the 22.
Roger that. Items coming in next week;
Carbon strap set with posts and twist nuts
Carbon front tower
Carbon mm tower
Alloy diff nut
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-31-2012, 02:38 PM   #2272
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Carbon front tower
Carbon mm tower
Alloy diff nut
Are there plans to finish out the steering system in aluminum with aluminum steering arms?
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 10-31-2012, 03:13 PM   #2273
t8rtot's Avatar
Trader Rating: 14 (94%+)
Carbon front tower
Carbon mm tower
Alloy diff nut
Paypal locked and loaded
Sfida
t8rtot is offline   Reply With Quote
Old 10-31-2012, 03:36 PM   #2274
MikeR's Avatar
The steering cranks yes- mid Nov. Will have a few more key parts come in during Nov actually. I will need to add a Kyosho section to the shop lol.
Old 10-31-2012, 08:16 PM   #2275
NTR
Well, tonight was a testing night for me. I ended up making the following changes (keep in mind i am running mid motor on a dirt track):
-went to 25 degree caster on the front bulkhead
-2 degree caster on front caster blocks
-went to the RF rear suspension holders
The cars rear end is more locked in then ever and the car has an insane amount of steering (insane as in just the way i like it )
also allowed me to drive the car much, much harder coming out of the corner, gained half of a second on fast lap.. wont be racing until wednesday though, taking a couple personal days off work and heading to the west coast for some family stuff.
Old 10-31-2012, 10:26 PM   #2276
silvalis's Avatar
Trader Rating: 29 (100%+)
I put the narrow hangers from my RB5 back on too.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-31-2012, 10:37 PM   #2277
Trader Rating: 139 (100%+)
With Gullwing or WC arms? I am thinking about trying the wide suspension mounts with the WC arms, or flipping around the gullwing arms and using the single hole that is there with RF2 suspension blocks. I agree this car has MAJOR amounts of steering, I can turn inside of B4.1's like they are not even there, have won a couple of races doing this. And have gotten a bunch of s**t from AE drivers because of it. The car is phenomenal in that respect, but in truth I could use dialing down a bit of steering so I am trying the 4 inserts in the caster blocks to tame the beast a bit. If only Losi could dream of having a car that is as long as the 22 and steers like an Associated. lol.... they got the 22 all wrong, just like the last few cars before.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-31-2012, 10:41 PM   #2278
From my B4.1 to the RB6 I dropped 3 complete seconds off my lap times on my track I raced on no lie.
Old 11-01-2012, 12:16 AM   #2279
alana07's Avatar
Send a message via MSN to alana07
so that equates to $150 per each second dropped on your lap times...$ well spent!!
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 11-01-2012, 12:16 AM   #2280
gelshocker's Avatar
When you mention WC arms, these are the 2-hole UM521 right? The 1-hole UM521-1 are the SP2 arms.
Going to stock up spares, are the stock front towers holding up? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Hilbouy
