    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 08-03-2012, 09:23 AM   #211
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Like this?
+ YouTube Video
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-03-2012, 09:49 AM   #212
ruf
ruf's Avatar
Send a message via AIM to ruf
I've always liked the bottom bleed (Losi style) better than the top bleed. The Kyosho shocks mix the best of all shock designs, IMO. Tamiya cylinder and piston quality, Losi bottom cartridge and bleed, upper rebound bladder, big bore, and high quality springs and x-rings (though rumor has it that the new Tamiya x-rings are even better). The only things I could think to add are advanced shaft coating (though it doesn't seem to need it) and bleeder top caps for even more tuning options.
Joe Chen
www.reflexracing.net
ruf is offline   Reply With Quote
Old 08-03-2012, 09:58 AM   #213
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
I have a question...
What is the advantage in having the front shocks mounted on the back of the tower as opposed to the front of the tower as with the old RB5?
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 08-03-2012, 10:12 AM   #214
Orion_2kTC's Avatar
What is this infamous T Plate you folks keep referring to? What's it do, why is it so bad?
Orion_2kTC is offline   Reply With Quote
Old 08-03-2012, 10:16 AM   #215
Rfury's Avatar
Apparently a few people had issues with the T-plates breaking. I think I broke 2 in nearly 5 years and it was because I hit something quite hard.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 08-03-2012, 10:20 AM   #216
toast.'s Avatar
Trader Rating: 14 (100%+)
What does it improve over stock t-plate?
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 08-03-2012, 11:57 AM   #217
CanyonCarverR1's Avatar
Originally Posted by big chris View Post
Because...Putting it in the rear has always been forbidden, hence we want to do that.
CanyonCarverR1 is offline   Reply With Quote
Old 08-03-2012, 01:58 PM   #218
mdowney's Avatar
Trader Rating: 21 (100%+)
Originally Posted by CanyonCarverR1 View Post
Did he run the motor forward or back?
Rear motor. As has been said, mid motor is intended primarily for super high grip carpet/turf tracks that are popular in Europe (better for bad weather and can be built indoors). This allows Kyosho to stay competitive in those markets where Schumacher, Losi and Durango currently dominate. I'm sure some will run it on high-bite clay but rear motor will remain the preference for dirt.
Originally Posted by Rfury View Post
Did he mount the ESC on the tray or flat on the chassis behind the battery? It will be great to see pictures.
There isn't an ESC tray. It sits on the chassis right behind the battery, which puts the weight as low as possible, lowering the CG. He chose to mount his Rx in the traditional position but it looks like they suggest putting it on the battery strap as an option. Depends on the size of your Rx. The KO's that Tebo runs are really tiny. The Kyosho Rx's seen in the PR photos are probably too big to fit on the side.
I'm not sure if there's a geometry benefit but I do know that mounting them behind the tower allows you to protect your suoer-expensive, annodized shocks with a cheap shock tower.
I'd much rather have the tower take the hit than my shocks. Not to mention the fact that a hit could move your preload collars. This is how the B4 does it.
The plastic T-plate, found on all of the current Gen K race kits is considered one of the most likely parts to break. I've only broken one, which was on my SC-R. The gearbox appeared to have punched through the t-plate somehow. The new car gets rid of this part and just extends the alu chassis all the way back.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 08-03-2012, 02:07 PM   #219
Rfury's Avatar
I see now! That is fricking trick! Stupid depth perception! I run Airtronics and my receivers are bigger than the KO but not by much. I might be able to fit it in the side as well.
When I first looked at the PR photos it seemed like the ESC sat above the battery like the 22(hated that btw when I had one) but it is actually behind it on the chassis.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 08-03-2012, 07:22 PM   #220
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
oh well
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 08-03-2012, 07:44 PM   #221
Davidka's Avatar
Trader Rating: 76 (100%+)
In the case of this car, I think it's to clear space to run the reverse bell crank setup.
Old 08-03-2012, 08:08 PM   #222
vertical-20's Avatar
i want one of these lol, kyosho has been my go to brand just because my first rc was an ultima rb gp lol.
-Voando
vertical-20 is offline   Reply With Quote
Old 08-03-2012, 08:53 PM   #223
lbckevin's Avatar
Trader Rating: 91 (99%+)
From liverc.com
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is online now   Reply With Quote
Old 08-03-2012, 09:13 PM   #224
BranVita's Avatar
Trader Rating: 39 (100%+)
Originally Posted by lbckevin View Post
From liverc.com
Awesome pics Kevin, I wonder if thats a Rt6 in the background
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 08-03-2012, 10:51 PM   #225
GTempleton's Avatar
Default RT6
I sure hope there is a RT6 is on the way.. Please Please
GTempleton is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Today 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
M3CSLDreamin
