    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-29-2012, 10:45 PM   #2221
hi, i am new to offroad rc and to this buggy. I want to run 64 pitch on this car. what are all the parts i need to do that? can anyone post a link? thanks !
rcnewb123 is offline   Reply With Quote
Old 10-30-2012, 04:54 AM   #2222
rokitman's Avatar
Trader Rating: 128 (100%+)
I was just looking at the pics that people have posted. Is there a reason noone is using the channel for the wiring? I ran my servo wire through it.
Didnt know if there was a problem with doing this, I just thought it was alot neater in it.
rokitman is offline   Reply With Quote
Old 10-30-2012, 04:55 AM   #2223
My Savox wire doesn't fit.
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 10-30-2012, 05:17 AM   #2224
rokitman's Avatar
I got my savox wire in it. Was snug but worked.
Old 10-30-2012, 05:19 AM   #2225
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
I like the channels.Makes for a clean look if that is what you like.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-30-2012, 05:31 AM   #2226
rokitman's Avatar
I was just wondering if there was a problem with using them. Im gonna use them. Just gotta figure out how to hold batt from the front with my aluminum posts in and put motor/esc in and mines good to go.
What pinion should I be running on the 17.5? Im gonna start with that motor and work my way to the 8.5
thanks
Old 10-30-2012, 05:37 AM   #2227
rokitman's Avatar
I saw where most are running 31-33t on 70 losi. I was gonna run the 76, maybe in the upper 20's would be a good place to start?
Old 10-30-2012, 08:05 AM   #2228
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I was / am planning on it.. but needed to get the car together for a big race so I ran out of time. I also wanted to make sure I liked my electronics placement beforehand. Next time the electronics get rewired or moved... I will have the time to use the pods.
For a 17.5? No...but it totally depends on what motor you are running, how much endbell timing you are running, and what rotor you are running. I run the following in mine (blinky mode)
Fantom Apex 17.5 (Epic Revtech)
12.5 high torque rotor
31/69
maxed endbell timing
90x60 indoor clay track
temps around 125
fastest 17.5 on the track
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-30-2012, 08:50 AM   #2229
NTR
31/69
temps around 125
Agree completely, right now my 17.5 setup:
Novak 17.5
High rpm stator
Vented end bells
Ceramic bearings
No ring around center of the motor
Two shims behind the rotor (spaces the rear of the rotor more away from the sensor board)
12.3 rotor
Timing on end bell is so that the middle wires of the sensor wires are right infront of the screw closest to the wires (if you look at the motor from behind its the top left silver screw)
Right now i am geared 30/69 and it is ballistic fast.. Passed a couple mod trucks on the staright.
Motor temps about 145 after a full battery (15 or so mins.)
Track is about 80x90 and is just a normal dirt track (no clay)
NTR is offline   Reply With Quote
Old 10-30-2012, 09:12 AM   #2230
frito's Avatar
Trader Rating: 59 (100%+)
Ready to do work
Kyosho Ultima RB6 & RB6.6 Car Thread-004.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-003.jpg
rc8b3e
b44.3
bfmce
t5m
radioactive raceway
frito is offline   Reply With Quote
Old 10-30-2012, 09:46 AM   #2231
t8rtot's Avatar
Trader Rating: 14 (94%+)
black anodized everything?? nasty
Sfida
t8rtot is offline   Reply With Quote
Old 10-30-2012, 10:08 AM   #2232
Moderator
Posvar's Avatar
Nasty good or bad?
Old 10-30-2012, 10:35 AM   #2233
CanyonCarverR1's Avatar
Originally Posted by Posvar View Post
Nasty good or bad?
Like Brittany Spears in a school uniform
CanyonCarverR1 is offline   Reply With Quote
Old 10-30-2012, 10:36 AM   #2234
Moderator
Posvar's Avatar
That totally depends on your interpretation of attractive.....let's get back on track. HEHE
Old 10-30-2012, 11:19 AM   #2235
t8rtot's Avatar
Nasty good or bad?
in a good way
Sfida
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
