    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-29-2012, 09:04 AM   #2176
fastestwon's Avatar
Trader Rating: 15 (94%+)
Originally Posted by 305M3 View Post
Caught part of a pipe last night and broke the rear pivot block part: UM508C.
Can I replace this part w/ the ST Racing Aluminum Rear Pivot Block Set that is listed for the RB5?
Part: http://www.teamstrc.com/index.php?ro...product_id=688
The RB5 part is: UM508B, which is the same as the ST Racing block. UM508C is the same as the UM508B, but has been updated for the wing mount - according to the description.
Can I use the ST Alum Rear Pivot Block set on the RB6?
Thanks.
yes you can i use them. you can't use the steel bushings thou use Kyosho Special Suspension Bushing (ZX5, RB5, RT5, SC, DB) - Package of 8 part # KYOLAW32
fastestwon is offline   Reply With Quote
Old 10-29-2012, 09:05 AM   #2177
t8rtot's Avatar
Trader Rating: 14 (94%+)
does anyone have a good start for mid on dirt i saw the one a few pages back but i'm looking for as much data as possible
Sfida
t8rtot is offline   Reply With Quote
Old 10-29-2012, 09:09 AM   #2178
Trader Rating: 137 (100%+)
Thanks.
Just remember you'll need to retune because the kit uses the wide suspension mounts, and with the STRC parts your going to a narrow rear end. If you used the parts they tell you to in the manual that is.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-29-2012, 09:10 AM   #2179
Maxthepersonz's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Cpt.America View Post
What does this post even mean?
He doesn't even know
Serpent Spyder SRX-2 asap...
Airtronics M12...
MARCCA Racing, Trackside, Performance Hobby Center...
Maxthepersonz is offline   Reply With Quote
Old 10-29-2012, 09:16 AM   #2180
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
TQ and win Sat night club racing in 17.5... car is unstoppable.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-29-2012, 09:16 AM   #2181
Slant EyEs's Avatar
Originally Posted by Kraig View Post
Slant EyEs (Jason?): if you have any feedback to Diggity or maybe they are reading this perhaps they could put a tongue on the front of the battery strap to help keep that piece of foam in the car during violent crashes. Or is it stuck in there pretty good from the bottom?
The Lipo holder is raised about 5mm, so the foam gets stuck under that and does not seem to go anywhere. Since I am running the battery a different way, most people will not have this issue. If you choose to run your battery this way and wanted one of his battery straps, you can just ask him to put that "tongue" in front to hold the foam. He would have no problems with that...
-Jayson Pang-
Kyosho America - Peak Racing - KO Propo - AKA - DE Racing - Diggity Designs - Speedtech R/C - Team Slant EyEs
Slant EyEs is offline   Reply With Quote
Old 10-29-2012, 09:16 AM   #2182
305M3's Avatar
Trader Rating: 40 (100%+)
Thank you and fastestwon - thanks.
By retune, what in particular? My apologies for such a general question, but this is my first foray in the 1/10 buggy scene. Being a nitro 1/8 buggy and truggy guy, I'm amazed at how changing a 1mm collar - for example - will change the set up on this thing.
305M3 is offline   Reply With Quote
Old 10-29-2012, 09:20 AM   #2183
fastestwon's Avatar
the narrow gives more rear bite then the wide
Old 10-29-2012, 09:22 AM   #2184
This car is very sensitive to setup changes. By retuning I mean your going to be putting on a rear end that is 1mm narrow on each side of the car. What that does to your setup you'll have to see and compensate for. my guess would be a loss of some rear stability. Geometry would be off from stock on the entire rear end of the car.
Old 10-29-2012, 09:32 AM   #2185
NTR
Honestly, start with the stock setup, and put 35wt shock oil in the front and 27.5 in the rear. Then tune from there. You really just need to change a couple camber links after that.
Do you plan on making the trip out to fastlane raceway in blue springs any time soon?
NTR is offline   Reply With Quote
Old 10-29-2012, 09:51 AM   #2186
CanyonCarverR1's Avatar
Originally Posted by Slant EyEs View Post
So its been a while since I have posted on here, but I figured I would help out my sponsors and show off my RB6 build and what they have helped me with. Just a disclaimer, I built it the way I wanted it to look and hopefully perform to my best abilities. And in no way state that you have to do what I did. We are all adults, well most of us, and you can do whatever you like to your toys.... Period...
So with that said, enjoy, comment, flame and ask questions....
Front shock tower is pre-production?
CanyonCarverR1 is offline   Reply With Quote
Old 10-29-2012, 09:56 AM   #2187
drstrangelove's Avatar
Finally, completed this new baby of mine! As always I took my time with the build up so that I can get to fully enjoy the whole process and experience. As usual with Kyosho, everything fit nicely.
Try to keep the whole wiring as neat as possible.
Follow Jared style with the placement of ESC and receiver
Happy with the soldering work, glad I still can remember how to do it correctly... (I guess)
Finally, see what happen to my friend new RB6, he took it out last Saturday and after a few run dented the chassis quite badly and today he tired to bend them back out and that's what he got.
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 10-29-2012, 10:17 AM   #2188
kdub's Avatar
Originally Posted by Eric Summers View Post
i like the idea of silicone, wax or grease the trani bottom and silicone the recessed area that way it doesn't stick to the trani bottom.
any word on the Avid Triad slipper for the RB6?
ems
We should receive the parts this week, so after some photos and QC, they'll be online by next week. We will also have a fresh batch of Triad clutch sets for order as well.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 10-29-2012, 10:20 AM   #2189
305M3's Avatar
Rear stability... Not something I would want to give up. I'll just go w/ stock and focus more on staying off the pipe.
Thanks all.
Old 10-29-2012, 10:32 AM   #2190
fastestwon's Avatar
Default race video from sunday
http://www.youtube.com/watch?v=ovWZ7...ature=youtu.be
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
