    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 10-27-2012, 05:02 AM   #2131
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by aloksatoor View Post
On a side note, never had trouble with the rango ball diff esp with bfast kits.
Heh. I had nothing but trouble with the rango balldiff. Probably just user error though
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-27-2012, 05:48 AM   #2132
Trader Rating: 138 (100%+)
Had the rango. Hated it. Got a used rb5 and even without tuning it, was way way better than the rango. the shocks itself put it a cut above the rest. Building my rb6 tomorrow but if the older ones better than the rango then for sure this woudl be too . Go for it.
When I had my DEX210, first thing I did was put a B-Fast diff in it (stock diff was horrible, one chirp and it was gone). Never rebuilt it in the whole 5 months I had the car. Very nice kit, for a very sub par rear motor car.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporqary 4 wheel), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-27-2012, 10:22 AM   #2133
Trader Rating: 84 (100%+)
Since the RB6 is about the same wheelbase and length as the RT5 has anyone thought about or tried converting their RT5 to a mid mount configuration using RB6 parts?
mike_d is offline   Reply With Quote
Old 10-27-2012, 10:25 AM   #2134
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Chris-s View Post
Considering picking up an RB6 to replace my 210, as I'm finding the 210 poor in low traction conditions (grip/balance) and in high grip the ball diff isn't up to the job (gear diff is slower!) and is inconsistent (but still quicker than gear diff!)
Looking to hear from people who have either tried both or have made the switch themselves. Did your laptimes fall and become more consistent?
The RB6 is considerably better than the 210 in all areas of measurement, except for one... and that is the ball diff. The dex210 is the worst car, with absolutely the best ball diff on the 1/10th market. (I would place the kyosho ball diff in a distant second).
Regardless, the RB6 is a better car all around. Just find somebody that has one dialed in to your track, and ask to drive it.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-27-2012, 11:19 AM   #2135
CanyonCarverR1's Avatar
Default Internal gear ration
Anybody know the internal gear ratio in rear motor config?
CanyonCarverR1 is offline   Reply With Quote
Old 10-27-2012, 12:35 PM   #2136
That is an interesting question, does adding the extra gear change it from 2.6?
Old 10-27-2012, 12:36 PM   #2137
RT6. Just add aluminum chassis and front end bits..... I love my RT5 just the way it is. If they do work on a new truck I hope they only change the chassis. Everything else is just fine the way it is.
Old 10-27-2012, 12:38 PM   #2138
wrightcs77's Avatar
Trader Rating: 521 (100%+)
Gear ratio does not change if you add the extra gear. They are the same tooth count, so no ratio change.
wrightcs77 is offline   Reply With Quote
Old 10-27-2012, 12:39 PM   #2139
I'm not sure, but I don't think so...just wasn't sure.
So the 3 gear tranny is 2.6? What's the formula for that?
Old 10-27-2012, 01:23 PM   #2140
vysoto's Avatar
Trader Rating: 15 (100%+)
The second one is butter. Mine bent too easily.
Don't get it in the kit form instead order 6 of the thicker 3.5mm version rather than the 3.0mm. http://www.amainhobbies.com/product_...-Turnbuckles-4.
Do not go for the longer ones they will not work with the kyosho long ends. You will have to order the shorter ones instead from kyosho for the lazer or something.
Will the rod ends still work the the thicker rods?
vysoto is offline   Reply With Quote
Old 10-27-2012, 02:01 PM   #2141
I love my RT5 as well and although it works fantastic on dirt it doesn't always work well on Astroturf/carpet tracks. That is why i was looking to try a mid motor configuration like a lot of the guys in europe do. Seems to work well for them. Obviously it will take more than just the chassis and front end parts won't it? What about the 4 gear tranny, etc...?
Old 10-27-2012, 02:07 PM   #2142
Wonder why the dropped the RB5 WC vented slipper from the RB6. I know it shares same slipper parts as FS, so cost saving..?
Anyone using vented slipper? Also been mentioned that some are upgrading the motor plate.
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 10-27-2012, 02:26 PM   #2143
I have both the vented slipper, and vented motor plate. Keeps my motor maybe 5 degrees cooler then stock. More for bling factor for me.
Old 10-27-2012, 02:29 PM   #2144
It wasn't really designed for mid motor, just like the 22 has mid-motor as an afterthought and the DEX210 is a mid-motor car with rear motor as an afterthought.
Of course it will take more then what I mentioned, but I was talking about a rear motor car. I don't have any tracks near me where it is worth the time investing resources to try and get mid motor working on the 6. Although out of the 3 rear/mid motor cars the Kyosho would probably be the easiest to find a mid motor setup for. Maybe Hot Rod Hobbies on a blue grooved track it would work.
Old 10-27-2012, 02:33 PM   #2145
I hear you. I was just curious if it was possible without breaking the bank just because I would like to try it to see how it would handle. By no means am I unhappy with my RT5 it's still an amazing truck! Thanks anyways and sorry for highjacking, back to the RB6 talk!!!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 Yesterday 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
