    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-25-2012, 04:13 PM   #2101
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by toast. View Post
Which is the correct turnbuckle kit for RB6 or do I need both?
LNS2685
LNS2686
The second one is butter. Mine bent too easily.
Don't get it in the kit form instead order 6 of the thicker 3.5mm version rather than the 3.0mm. http://www.amainhobbies.com/product_...-Turnbuckles-4.
Do not go for the longer ones they will not work with the kyosho long ends. You will have to order the shorter ones instead from kyosho for the lazer or something.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 10-25-2012, 04:44 PM   #2102
joecool's Avatar
Trader Rating: 19 (100%+)
I just ordered mine directly from lunsfordracing.com
You need a total of 6 1 5/8" titanium turnbuckles. Your choice of 3mm or 3.5mm.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 10-25-2012, 05:24 PM   #2103
Kooz's Avatar
Custom RB6 Chassis skins from Darkside Design!
http://www.ebay.com/itm/Custom-Kyosh...item564df67eed
Kooz is offline   Reply With Quote
Old 10-25-2012, 05:45 PM   #2104
aloksatoor's Avatar
nice stuff darkside.
Old 10-25-2012, 07:39 PM   #2105
eper's Avatar
Trader Rating: 14 (100%+)
i'd like chassis skins if they had the screw holes pre punched. i hate having to cut up my skin to work on my buggy
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 10-25-2012, 08:30 PM   #2106
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Kyosho has posted yet another setup for the RB6. This time it is from Cody Turner at HRH.
http://www.kyoshoamerica.com/assets/...tup_sheet1.pdf
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 10-25-2012, 09:18 PM   #2107
toast.'s Avatar
Need recommendations for a 'base' setup, will be using my RB6 at WCRC and a smaller, more technical high grip local track. Is this the 'Japanese Setup' that is popular?
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 10-25-2012, 11:15 PM   #2108
mobb187az's Avatar
I'm looking at picking a rb6 up soon, I drive a b4.1 currently . Is this car agile like the b4? I wasn't a fan of the 22..
Durango dex210
Losi sct
www.Sticky-Kicks.com - Tire Conditioner and Traction Sauce
mobb187az is offline   Reply With Quote
Old 10-25-2012, 11:24 PM   #2109
drstrangelove's Avatar
Hey guys, be careful when you put any clay in the area. I did that yesterday and I end up putting too much (how much is too much to start with??). When I screw them down, the chassis balloon out!
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 10-26-2012, 12:02 AM   #2110
silvalis's Avatar
Trader Rating: 29 (100%+)
huh.
Maybe I can push the dent back out doing that.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-26-2012, 01:59 AM   #2111
chrispattinson's Avatar
I tried the RB5 T plate piece, (I'm running the car in mid motor config).
Even with a thinned down T piece, the chassis was balooning out, and so I have decided to not run the insert, but will be running a lexan plate underneath the rear.
The material is so thin in this area is so thin you can flex it easily between your thumb and forefinger.
chrispattinson is offline   Reply With Quote
Old 10-26-2012, 02:31 AM   #2112
Interesting to know Chris, I was looking at this option during the build. I may just get my DB1 out instead!
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 10-26-2012, 04:28 AM   #2113
fastestwon's Avatar
Trader Rating: 15 (94%+)
Post up a pic of your insert . Like to see what is different then the one I made . Mine is perfect
fastestwon is offline   Reply With Quote
Old 10-26-2012, 05:47 AM   #2114
Trader Rating: 77 (100%+)
Start with the Tebow set up with the kit rear arms. Change the shock eyelets in rear to the long ones. Shocks are Losi 55 pistons with 30 wt front and 27.5 rear.
Drew Muller will be posting his WCRC set up shortly but it is close to that.
goin2drt is offline   Reply With Quote
Old 10-26-2012, 06:33 AM   #2115
There are a number of setups available for WCRC, I recommend not starting with the Tebo or the Japanese setup. Instead Cody, Drews, or my setup will be better for you to start with, all of which are or will be available on Kyosho's website.
http://www.kyoshoamerica.com/Factory-Setups_c_842.html
I have a slightly updated version of my setup on my site as well.
http://jasondias.com/2012/10/12/kyos...st-rc-raceway/
Jason.Dias is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22956 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
