Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 10-24-2012, 12:11 PM
  #2056
Trader Rating: 166 (100%+)
Originally Posted by toast.
Won't adding clay bump up the weight?
It would but I don't think to the extent of being a problem. The problem would be making it look decent, and evenly spread.
jpcopeland1 is offline
Old 10-24-2012, 12:19 PM
  #2057
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
A plastic insert would be awesome.
Posvar is offline
Old 10-24-2012, 12:23 PM
  #2058
can somebody tell how much wider are the wide rear end hinge pin holder compered to standered ones i broke the wide ones all i could find the regular ones for now at least i can still run it
hollywood7 is offline
Old 10-24-2012, 02:16 PM
  #2059
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I haven't measured it yet, but they are substantionally wider... If I had to guess, I would say 3 or 4mm. (total, not per side)
Running the narrower ones will simply give you slightly more rear traction, and slightly less steering in the corners.
Cpt.America is offline
Old 10-24-2012, 02:24 PM
  #2060
thanx capt steering is not a problem almost too much im running vectors on the front i have run them backwards to tame it down a bit!
Old 10-24-2012, 02:35 PM
  #2061
Moderator
Posvar's Avatar
Ooops, I thought the wider ones gave more rear traction.
Posvar is offline
Old 10-24-2012, 02:40 PM
  #2062
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Me too. How do they make it looser in the rear?
aloksatoor is offline
Old 10-24-2012, 04:29 PM
  #2063
ems
Eric Summers is offline
Old 10-24-2012, 04:31 PM
  #2064
SpeedTech's Avatar
Originally Posted by Cpt.America
Ironically, they have coupon codes too! Even better pricing on their already more than fair pricing. (no, i dont work for speedtech)
no... BUT I DO!!!
Thanks everyone for the support. We appreciate it very much. More great things to come...
Coupon codes in the sig.
Cheers,
Jeff
SpeedTech is offline
Old 10-24-2012, 05:05 PM
  #2065
Woulvesbaine's Avatar
Originally Posted by SpeedTech
no... BUT I DO!!!
Cheers,
Jeff
Are you guys in SG Valley or something? If so, importantly, how far from my Sunday kitchen (888)?
Woulvesbaine is offline
Old 10-24-2012, 05:51 PM
  #2066
Originally Posted by Eric Summers
ems
how much are selling those for
Old 10-24-2012, 06:09 PM
  #2067
jnslprd's Avatar
Is that paneling?
jnslprd is offline
Old 10-24-2012, 06:20 PM
  #2068
eper's Avatar
Trader Rating: 14 (100%+)
I think modeling clay or anything that doesnt become solid would end up pushing out around the chassis on impact and the chassis would do the same thing. My chassis hasnt done this and ive had lots of hard hits. The plastic insert seems like the best fix. Other then that im thinking of putting a small amout of JB weld in there then mounting just the transmission to the chassis, cleaning up what ever excess weeps out around the tranny and letting the JB weld set up for about 30 minutes then i'll remove the chassis and let the JB weld cure the rest of the way which will make it so the tranny doesnt become welded to the chassis. If i do this i will let everyone know how it goes. If any of you have opinions or ideas on this method please post them.
eper is offline
Old 10-24-2012, 06:26 PM
  #2069
frito's Avatar
Trader Rating: 58 (98%+)
Fixn start my build anything I need to know or do?!
frito is offline
Old 10-24-2012, 06:35 PM
  #2070
I think a thin 1mm or so skid plate might be the best option for now. I would prefer to see a plastic plate rather than a metal one. Mush lower cost I would assume with plastic over metal.
Maybe some company will make something to fill the gaps or a skid plate of some sort.
Rfury is offline
