    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-23-2012, 08:34 PM   #2026
powerslave's Avatar
Originally Posted by Rfury View Post
Unless the screws strip out of the trans case or the case breaks, I would not see the chassis bending as it has for some people with a case that fits properly.
I agree, if it fit in perfect we wouldn't have a problem
powerslave is offline   Reply With Quote
Old 10-23-2012, 09:20 PM   #2027
Trader Rating: 137 (100%+)
Hard to say what happens with things. Mine I know has taken tons of abuse when I cant clear the rather large triple at West Coast RC in stock and have cased the top of the last jump who knows how many times and nothing. I don't think running chassis tape would fix that kind of issue.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-23-2012, 09:22 PM   #2028
Originally Posted by eper View Post
i wonder why they made the tail section of the chassis thinner then the rest? anyone have any ideas on this, and are the people who are denting the chassis setting ride height on the thinner part of the chassis. the way the setup sheet look it should be measured under the rear bulkhead, just wonder if that may be causing excessive chassis slap
That would be a good question to direct to the designer. Nobody I know who has the car has had this happen, with or without chassis tape.
Old 10-23-2012, 09:26 PM   #2029
Originally Posted by powerslave View Post
I just stripped my chassis down to ship to Kyosho. Took some measurements with my calipers,the rear chassis thickness is 2.5mm the milled out trans section seems to be 2.1mm deep,that little square doesn't stand a chance.
I wish they would have made a cut out in the chassis for the transmission!
That is a sensible alternative, but how long until they actually can make this change when they cant even keep rear arms in stock?
Old 10-24-2012, 02:06 AM   #2030
chrispattinson's Avatar
In the mean time, would a small polycarbonate plate, maybe made from bodyshell lexan, cut to fit the rear section and screwed on underneath protect the chassis sufficuently?
It may help protect from scratching, and spread the load of any impacts over a bigger area?
chrispattinson is offline   Reply With Quote
Old 10-24-2012, 04:14 AM   #2031
asc6000's Avatar
Trader Rating: 15 (100%+)
had to go back 5 pages to see what all the chat was about, while going back from page 136 to 131 I found it funny as a couple of people who posted what seemed like detailed info about the design didn't even have an rb6. no big deal just funny. So when I finally saw the pic I just thought about how nice those A.P.E. plates are....
Surely in testing someone at some point cased that spot so I would be surprised if K got the "design" wrong.
Does the chassis get treated after machining? perhaps this is simply a bad batch of chassis.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 10-24-2012, 05:55 AM   #2032
This posted earlier by steam "I was told the next batch of cars should be here in the US in early November."
got me thinking Kyosho putn' out more thin batched chassis.
ems
Eric Summers is offline   Reply With Quote
Old 10-24-2012, 07:31 AM   #2033
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Nobody is saying that any kind of chassis tape would help this issue. The two things that we think would help this temporary issue, are
1) Filling in the excess recess area, under the tranny case, with clay (as suggested by kyosho). and/or
2), running a plastic (or whatever material) skid plate over the back of the chassis.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-24-2012, 07:43 AM   #2034
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Modeling clay?
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-24-2012, 07:48 AM   #2035
t8rtot's Avatar
Trader Rating: 14 (94%+)
anyone tested mid-motor on dirt/clay? what springs and set up are you trying?
Sfida
t8rtot is offline   Reply With Quote
Old 10-24-2012, 07:58 AM   #2036
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Posvar View Post
Modeling clay?
That should work fine. You just need something fairly dense, but still pliable enough to fill in the gap.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 10-24-2012, 08:01 AM   #2037
Moderator
Posvar's Avatar
ok
Old 10-24-2012, 08:01 AM   #2038
carbons2k's Avatar
Trader Rating: 21 (92%+)
I jut noticed the indent on my chassis. I've had it for 3 weeks. Makes me wanna hold onto my rb5... Just in case.
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 10-24-2012, 08:06 AM   #2039
toast.'s Avatar
Trader Rating: 14 (100%+)
Won't adding clay bump up the weight?
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is online now   Reply With Quote
Old 10-24-2012, 08:11 AM   #2040
Moderator
Posvar's Avatar
It will be such a small amount of clay......
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
