    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 10-18-2012, 04:35 PM   #1786
jordy-15's Avatar
Trader Rating: 17 (100%+)
Originally Posted by C_Money View Post
What is the part number for the different size shock ends and also for the big bore spring retainers? I can't find them anywhere
you will find the part No. in the exploded view in the manual
cheers
:: Proline :: XRAY :: Muchmore::HEI ::
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
jordy-15 is offline   Reply With Quote
Old 10-18-2012, 04:51 PM   #1787
BranVita's Avatar
Trader Rating: 39 (100%+)
Originally Posted by MikeR View Post
Hi All!
I am ahead of schedule and have these in stock now for shipping tomorrow
http://www.exotekracing.com/rb6-alloy-steering-rack/
any date on when the black will be availble?
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 10-18-2012, 05:17 PM   #1788
steam's Avatar
Default Added Iphone link
This link should work for iphone peeps
http://youtu.be/06TNpEL_-_g
Originally Posted by steam View Post
Here is a video of Jason Dias buggy in action in a 17.5 non-timing pro-stock class. He's running it against current ROAR National champion Kevin Motter.
The below link should work for iphones =)
+ YouTube Video
Lap Times
http://www.liverc.com/view_result_fi...T_(A_Main).xml
Set up - I believe, not sure if anything changed for this race
http://www.petitrc.com/setup/kyosho/..._WCRC20121010/
Just to contrast the lap times
You might of heard of a few of these guys.
http://www.liverc.com/view_result_fi...D_(A_Main).xml
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 10-18-2012, 05:19 PM   #1789
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
The exotek piece is beautiful. When black is ready I am all in. Good Job!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-18-2012, 06:27 PM   #1790
rcfiend's Avatar
Trader Rating: 30 (100%+)
How many battery foam strips for the chassis did you guys receive? The manual shows two, but I only received one.
rcfiend is offline   Reply With Quote
Old 10-18-2012, 06:40 PM   #1791
jordy-15's Avatar
just 1 you have to cut it in half.
cheers
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
Old 10-18-2012, 06:44 PM   #1792
silvalis's Avatar
Trader Rating: 29 (100%+)
If you're referring to the back of the booklet where it gives you a p/n and number, that's how many you get when you buy it as a spare, not how many you get in the kit...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-18-2012, 06:53 PM   #1793
cheers
The instruction/assembly manual shows 2 seperate sponge tapes on step 48. No mention about cutting one in half
Lou Colmo/Tekno EB48.3, SL & SCT410.3/ Tekno R/C,Tekin / Reedy Batteries / Savox /AKA / Futaba 4PKs
Blaze R/C,St.Louis DirtBurners,SMAC Trac
X God is offline   Reply With Quote
Old 10-18-2012, 07:07 PM   #1794
jordy-15's Avatar
yeah the manual is a bit hard to follow
i measured the channels that the foam goes in and the width of the foam and worked out if i cut in half it would fit nicely
cheers
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
Old 10-18-2012, 08:17 PM   #1795
rcfiend's Avatar
cheers
Thx. That's what I thought. The manual just didn't say anything about cutting it in half.
Old 10-18-2012, 08:25 PM   #1796
K_King's Avatar
Send a message via AIM to K_King
Hi All!
Awesome, since I have a lot of Red on my car this is perfect.
Any chance you can make the other parts metal also like the RB6 originally showed?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-18-2012, 08:46 PM   #1797
gelshocker's Avatar
Hey guys do you notice any bump steer with the six, trying out the Japanese setup, thx
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-18-2012, 09:29 PM   #1798
K_King's Avatar
Well you will with all the bumpsteer added with those shims. I run 0.
Old 10-19-2012, 01:52 AM   #1799
racer x 1's Avatar
Trader Rating: 27 (100%+)
Finally I completed my rb6 body, wiring and all! pics in the morning! its so nice I dont even wanna put her down in the dirt. haha
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 10-19-2012, 08:29 AM   #1800
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I know, right? That is why I set up my little photo shoot so I could always remember what she looked like when she was new Do it.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
