    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 10-18-2012, 04:46 AM   #1741
steam's Avatar
Default RB6 Video running in the stock 17.5 non timing class
Here is a video of Jason Dias buggy in action in a 17.5 non-timing pro-stock class. He's running it against current ROAR National champion Kevin Motter.
The below link should work for iphones =)
http://youtu.be/06TNpEL_-_g
+ YouTube Video
Lap Times
http://www.liverc.com/view_result_fi...T_(A_Main).xml
Set up - I believe, not sure if anything changed for this race
http://www.petitrc.com/setup/kyosho/..._WCRC20121010/
Just to contrast the lap times
You might of heard of a few of these guys.
http://www.liverc.com/view_result_fi...D_(A_Main).xml
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 10-18-2012, 04:50 AM   #1742
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Nice. The car does not seem too heavy to run 17.5 blinky.....
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-18-2012, 05:23 AM   #1743
rokitman's Avatar
Trader Rating: 128 (100%+)
stuff like that is gonna make me pull the trigger on one...
rokitman is offline   Reply With Quote
Old 10-18-2012, 05:34 AM   #1744
lewis4x4's Avatar
Nice setup...
Brian "B-Daddy" Lewis
XRay, Proline, Absolute Hobbyz, RC America, Airtronics, Murnan Modified Motors, Team Trinity, Kustom RC Graphics, Schelle Racing, MIP, LFR, StickIt1 Racing, Team Lewis Racing
lewis4x4 is offline   Reply With Quote
Old 10-18-2012, 06:03 AM   #1745
steam's Avatar
Default Roll over
Yes but as you can see at the 1:56 mark it doesn't roll over well
Old 10-18-2012, 06:07 AM   #1746
jkirkwood's Avatar
Originally Posted by lewis4x4 View Post
Nice setup...
64 Pitch spur and pinion.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 10-18-2012, 06:27 AM   #1747
toast.'s Avatar
Trader Rating: 14 (100%+)
How about Hot Bodies Beams?
Originally Posted by \
jpcopeland1;11338810]It isn't so much the holes themselves as to where you place them. I myself put two holes in every set of rims I have just to let the tire breathe, and if I don't hear them breathe, physically holding the tire up to your ear and listening for air coming out, the either then hole is not big enough and needs to be enlarged, or the insert needs a couple of punches with a leather punch. This round of Clay Compound suburbs, I am taking a good pair of AKA closed cell inserts that have been broken in, and punching a couple of holes in them, and mounting on my new Suburb tires I just ordered. Been going through Pro-Line inserts like water lately and am tired of it. Sacrificing an almost brand new set of Jconcepts clay compound Bar Codes to do it (cutting at the inner bead and yanking out the inserts), but since I don't bother going back to the track where only those tires work well doesn't phase me. I wish there was really a 3rd option in tires where I race, but AKA and Panther don't seem to provide the grip I need for medium indoor wet clay. It's jconceots clay bar codes up front, and Pro-Line Suburbs back. Please would a 3rd manufacturer of tires hear my plea for another option, specifically AKA???????? In 8TH scale when I had my VE8 the Jconcets tires again were the only good choice in tires, Had major grip and didn't suffer from wheel spin as much as the Pro-Lines I bought along with the buggy. 8th scale is a totally different beast with all wheels going at the sdame time, need more balance as far as tires go and correct diff fluids (the most impotent). But again its the same thing, same tires, same inserts, boring...... The only good AKA trires I have run so far are the tires they make for indoor clay short course, and I don't like short course.
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 10-18-2012, 06:48 AM   #1748
Trader Rating: 18 (100%+)
Nice race vs Motter!
I run on a pretty low bite track compared to WCRC and been having the problem that happened at the 5:24 mark. It happens on tight turns with a short take off before a jump or a step down like in this video. As you can see the car gets a little loose but still squared up for the jump but puts the car in a uncorrectable roll. Anyone got any setup to help that? Yes, i know roll the throttle but there are times when you will need to punch it.
Tebo had the same problem @ :36 sec and 3:38 mark
http://www.youtube.com/watch?v=nZ1Dim8_QCA
Ryan Sagisi
Schelleracing.com | Raceaka.com | R1wurks.com
B5M | B44.2 | T4.2 | Top Photon
SAGISI is offline   Reply With Quote
Old 10-18-2012, 07:00 AM   #1749
+ YouTube Video
Lap Times
Wish I could view the vid....
Gitsum is offline   Reply With Quote
Old 10-18-2012, 07:04 AM   #1750
toast.'s Avatar
trying clicking on 'youtube' and see if you can view it from the youtube page
Old 10-18-2012, 07:21 AM   #1751
rokitman's Avatar
none of them "ROLL" well
Old 10-18-2012, 07:22 AM   #1752
NoPe iPhone fail
Old 10-18-2012, 07:30 AM   #1753
rokitman's Avatar
I just ordered mine..
Just want to see what all I can use from the the rb5 on the 6
I know I can use the arms as a tuning option. I am just trying to see if it would be just as good to use my sp and wc for spares as aposed to selling them.
Old 10-18-2012, 07:45 AM   #1754
t8rtot's Avatar
Trader Rating: 14 (94%+)
welcome to the family
Sfida
t8rtot is offline   Reply With Quote
Old 10-18-2012, 07:47 AM   #1755
rokitman's Avatar
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
