    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-17-2012, 08:50 AM   #1681
Just ran mine for first time all i can say is its worth every penny!! all i did is put softer avid springs on the rear this car has more steering than any rc car i have ever owned in 25 years i let one of the fast guys AE at our track take the wheel he had it flying around the track after a couple laps!! i still need a little more rear traction he said to try 3.5 in the rear i think stock is 3 i broke a rear hub carrier right before i left i thought i was out for a while but lhs had a o degrees aluminum in stock lucky me already got it on ready to race tomorrow!!
hollywood7 is offline   Reply With Quote
Old 10-17-2012, 09:33 AM   #1682
Default RB6 Aluminum Steering Rack
Originally Posted by Turbo911 View Post
We have RB6 Steering Racks in stock. Made from 6061-t6 Aluminum. Not anodized as we want to get these out in the market ASAP.
This item is listed for sale see page below.
RB6 Aluminum Steering Racks
Wow, thanks for the awesome response. The first twenty parts are almost gone. We are going to make 50 more tonight so as to not run out. Keep the orders coming. Any thoughts on other parts for the RB6, such as an adjustable rear hinge pin holder, aluminum steering arms or anything else that you come up with. Trying to help pay for my R/c addiction.
Kurt
Turbo911 is offline   Reply With Quote
Old 10-17-2012, 09:50 AM   #1683
Trader Rating: 22 (100%+)
Slice the foam in 1/2...
Originally Posted by X God View Post
Well I started the build last night, All that is left is shocks and installing the electronics and the body. 2 problems with the build.The kit was missing a front steering block pin and the battery foam(supposed to be 2 pieces) was 1 single piece. Other then that it was a very easy build.
noproblems209 is offline   Reply With Quote
Old 10-17-2012, 09:51 AM   #1684
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Can anyone tell me if the long/short/medium shock ends are included in the kit? I saw that Cpt switched to the medium(I think) to reduce droop and help calm the rear end.
Thanks!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-17-2012, 09:55 AM   #1685
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Thanks!
I used mediums I got from a team driver.. I looked on all my trees and could only find the tiny short guys. (which I tried, by the way, which were WAY WAY too short to make work).
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-17-2012, 09:56 AM   #1686
Moderator
Posvar's Avatar
Thanks. That is what I thought. I looked at Amain and can find the short and long but not the medium.......
Old 10-17-2012, 10:02 AM   #1687
Trader Rating: 1069 (100%+)
medium and long were in my box in a separate bag. Had no issue with getting the shocks to the japanese setup measurements.
Matt I have all 3 sizes I'm sure...
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-17-2012, 10:02 AM   #1688
Super Moderator
Matt... Since the long ones are pretty easy to find, There shouldn't be an issue just cutting them. I can measure the overall length of the mediums for you tonight when I get home... if you want, you don't want to cut too much. If you DO cut them, you want to make sure you use a nice set of digi-calipers to make sure you have them cut/ground down to the identical length.
- RCSpecialties -
Old 10-17-2012, 10:03 AM   #1689
Super Moderator
Mediums came with your 6? hhmm... ill have to dig more and see what I see... I could only see longs and shorts on my parts trees. Maybe i over looked them.
- RCSpecialties -
Old 10-17-2012, 10:07 AM   #1690
t8rtot's Avatar
Trader Rating: 14 (94%+)
yup there in there, in a separate bag
Sfida
t8rtot is offline   Reply With Quote
Old 10-17-2012, 10:08 AM   #1691
Moderator
Posvar's Avatar
Thanks Dave and Brandon. Yes please on the measurement if you get a chance.
I have shoulder surgery coming up very quickly and will have a four month recovery so I am freaking out about the little details. Soon all I will be able to do is just read the forum and stare at my K cars....
Old 10-17-2012, 10:17 AM   #1692
lbckevin's Avatar
Trader Rating: 89 (99%+)
mine came with the long and mediums as well.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-17-2012, 10:18 AM   #1693
Moderator
Posvar's Avatar
I'll go digging later tonight...
Old 10-17-2012, 10:24 AM   #1694
CanyonCarverR1's Avatar
My kit came with 4 mediums in a seperate tiny bag, not on a tree.
CanyonCarverR1 is offline   Reply With Quote
Old 10-17-2012, 10:45 AM   #1695
Registered User
Originally Posted by mojo tom View Post
Don't forget the orings, OR0145 or something.
Nothing special except maybe not overtighten the case.
People tend to run 1000 to 3000.
Heard Kyosho have steel gears available for the 1/10th onroad cars and they fit.
The car is really awesome, ran it only as a Mid motor.
Very happy, they did a great job on a lot of things.
Part number for the steel gear set is VZW-424, it's around $50 a set.
oosh123 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DriveKyosho
