    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 10-16-2012, 12:29 PM   #1651
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
yep.. I think 29 degrees caster will certainly be the ticket on this car.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-16-2012, 12:32 PM   #1652
t8rtot's Avatar
Trader Rating: 14 (94%+)
is there an easier way to get the inserts out?? i put some pretty good work in switching mine the other day.. and now they don't look to sexy. i even put silicone grease on them, still a pain to remove and switch
Sfida
t8rtot is offline   Reply With Quote
Old 10-16-2012, 12:50 PM   #1653
I pushed them with pliers from the back side...piece of cake!
nitroargi is offline   Reply With Quote
Old 10-16-2012, 12:52 PM   #1654
Post up some iPhone friendly vids of this car running.
Gitsum is offline   Reply With Quote
Old 10-16-2012, 12:57 PM   #1655
Retired09's Avatar
Default Bevel diffs
I just bought all the parts o build a bevel diff for my RB5.
UM610, Um605, UM611, UM613, UM612.
Is there anywhere that gives detailed assembly instructions, what diff oils to use, etc?
Which way the diff goes in transmission.
Thanks.
Bill Mason
Thanks to my Sponsors: Tekno RC, BUKU, Bones Motorsports, OS, Futaba, JConcepts
Clubs: AZRCR at Fear Farm (Arizona Radio Control Racers), TKO Kentucky Racers Club
Retired09 is offline   Reply With Quote
Old 10-16-2012, 01:05 PM   #1656
eper's Avatar
Trader Rating: 14 (100%+)
the wider rf blocks make the car rotate much better from the center of the corner out they also add to the stability due to a wider track width. most tracks i run at are medium to low traction and i still think the wide blocks are the way to go. just my .02 cents.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 10-16-2012, 03:18 PM   #1657
Thanks.
Don't forget the orings, OR0145 or something.
Nothing special except maybe not overtighten the case.
People tend to run 1000 to 3000.
Heard Kyosho have steel gears available for the 1/10th onroad cars and they fit.
The car is really awesome, ran it only as a Mid motor.
Very happy, they did a great job on a lot of things.
mojo tom is offline   Reply With Quote
Old 10-16-2012, 03:41 PM   #1658
Default RB6 Steering Rack
We have RB6 Steering Racks in stock. Made from 6061-t6 Aluminum. Not anodized as we want to get these out in the market ASAP.
This item is listed for sale see page below.
RB6 Aluminum Steering Racks
Turbo911 is offline   Reply With Quote
Old 10-16-2012, 06:42 PM   #1659
CanyonCarverR1's Avatar
PM sent
CanyonCarverR1 is offline   Reply With Quote
Old 10-16-2012, 08:09 PM   #1660
drstrangelove's Avatar
Hi Guys,
Can someone kind enough to tell me what is the different in rear motor and mid motor? I see in the manual they have two options. I will be going with the stock ie rear motor but just interested to know what is the different between the two and are all running rear or mid motor? What conditions should we run mid motor?
Also I'm looking at chaning the rear suspension to the aluminium one. But there is four options. Which one should I get? Or I need to get all 4 of them?
1) KYOUMW515GM - Kyosho Aluminum Wide Rear Outer Suspension Holder (Gunmetal)
2) KYOUMW514GM - Kyosho Aluminum Wide Rear Inner Suspension Holder (Gunmetal)
3) KYOUMW511GM - Kyosho Aluminum Rear Suspension Holder (RF) (Gunmetal)
4) KYOUMW512GM - Kyosho Aluminum Rear Suspension Holder (RR) (Gunmetal)
Cheers guys
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 10-16-2012, 08:26 PM   #1661
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Mid Motor is going to be used on super duper mega holy shit high grip. Most UK tracks, or those that use astroturf. If you run on dirt, unless your track is mega grip, I would just run the rear motor.
The mid motor is a lot more aggressive with steering, at the expense of rear grip.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-16-2012, 08:31 PM   #1662
lbckevin's Avatar
Trader Rating: 91 (99%+)
most guys have gone with the wide rear alum. mounts
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-16-2012, 08:44 PM   #1663
I see. Thanks mate. That does not sound like something I need. Rear it is. Cheers.
Old 10-16-2012, 08:46 PM   #1664
Thank mate, so which one I should go for? Sorry not very familiar with this 1/10 setup, my first.
Old 10-16-2012, 08:48 PM   #1665
silvalis's Avatar
Trader Rating: 29 (100%+)
#1 and #2 in your list...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
