    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-15-2012, 08:27 PM   #1621
Use the black one. The white gear strips over time. You will have no problems with the black "sp" idle gear.
Tom87 is offline   Reply With Quote
Old 10-15-2012, 08:52 PM   #1622
rcfiend's Avatar
Trader Rating: 29 (100%+)
Does anyone use the vented slipper instead of the one that comes with the kit?
rcfiend is offline   Reply With Quote
Old 10-15-2012, 08:57 PM   #1623
silvalis's Avatar
I just put the WC slipper, spring and washer onto mine.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-15-2012, 09:13 PM   #1624
rcfiend's Avatar
Yeah I did as well. I just took it off my RB5.
Old 10-15-2012, 10:09 PM   #1625
AZRC4Me's Avatar
Originally Posted by Cpt.America View Post
The RB6... the game changer.
In short, I think this car is the absolute best of all the chassis out. It's durable like the 22, it turns on a dime like the B4, and it's stable and planted like the RB5. It's only downside, is it's cost. But with what we spend in gas and tires.. .what's an extra $100 for the kit? Nothing... totally worth it, and it's totally gorgeous.
Nice report bro, and congrats! Way to represent
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 10-15-2012, 10:09 PM   #1626
lbckevin's Avatar
Trader Rating: 89 (99%+)
Sean...
I finally got my Rb6.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-16-2012, 01:42 AM   #1627
drstrangelove's Avatar
Hey Guys,
Got myself the RB6!! Now need some advise on a few things:-
I'm thinking of getting the following:-
1) For ESC: Vortex R10 Pro Brushless ESC (160A, 2-3S)
2) For Motor: Vortex VST PRO Modified 7.5
I'm slightly confuse on the ESC, they come in 90A and 160A. I started a thread asking about this and someone posted that if I'm using the modified motor I should go for the 160A esc. For those using Orion motor, what ESC are you guys using?
What other option parts I should get? Thinking of changing the rear hub to the alu one and maybe get the ceramic ball for the diff. Any advise appreciated.
sorry one more thing. Should I get the 150 or 110 mm sensor cable?
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 10-16-2012, 03:42 AM   #1628
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Get the larger amperage esc, aluminum rear hubs will drop in and are a good option, I would go with carbide balls in the diff and ceramic thrust balls, and the shorter the sensor wire the cleaner it will look. The 110 should be ok.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-16-2012, 04:11 AM   #1629
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
I'm tempted. Maybe when it's time to put the B4 down...
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 10-16-2012, 04:43 AM   #1630
Hey bro,
Thanks, nice to know that 110 sensor wire will fit in nicely. I will order that.
I don't quite understand this I would go with carbide balls in the diff and ceramic thrust balls. Are you saying I should mix the carbide and ceramic balls for the diff? Hope I'm not asking a stupid question.
Old 10-16-2012, 05:23 AM   #1631
Moderator
Posvar's Avatar
The carbide would be in the main diff in between the two rings. The ceramic would be in the thrust washer assembly on the outside of the rings. When looking at the manual it will make sense. No mixing!!! Lol
Old 10-16-2012, 05:49 AM   #1632
got it now, so you referring to item 147 in the manual? but the only sell the ceramic in item 151. Damn everything in 1/10 so small
Old 10-16-2012, 06:20 AM   #1633
Orion_2kTC's Avatar
Captain a while back I commented on the RB5 and asked how user friendly it would be for someone who's never built a car. Well the same question applies here? Is it build friendly? Can I run stock out of the box and have success? I'd rather spend the extra $$ on quality than just get by.
Orion_2kTC is offline   Reply With Quote
Old 10-16-2012, 06:22 AM   #1634
t0p_sh0tta's Avatar
K kits are as good as it gets quality wise. The manuals aren't the best, but they aren't bad either.
You've got us, and your LHS as good resources. The most important thing to remember is to not go crazy torquing down screws, as plastic does strip. Beyond that, just make sure everything moves freely (no binding, flashing, parts installed incorrectly, etc.).
Old 10-16-2012, 06:34 AM   #1635
Moderator
Posvar's Avatar
+1!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
