    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 10-14-2012, 07:36 PM   #1546
Trader Rating: 101 (99%+)
Originally Posted by RMKinWI View Post
What do I need to use a smaller spur? Seems Kyo doesnt make any smaller than stock spur 76. What gears are you guys running for Blinky 17.5?
I use the TLR 70t spur and Losi slipper pads with 17.5 NT. The Kyosho's slipper plates rest perfectly on the Losi slipper pads, whereas they rest on the AE/Kimbrough spur gears themselves.
Until Kyosho releases a smaller spur gear (Pillars knows we need one!), this is the best combo of spur/slipper pad so you can still utilize the slipper (if you want to?), without locking down onto the spur gear itself. Some run 17.5 NT with locked slippers... Others (myself included), prefer the feel a slipper provides. Either way, you have options!
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 10-14-2012, 08:09 PM   #1547
kdub's Avatar
The AVID topshaft for RB5 / RB6 is coming within a couple weeks. We improved on the gear mesh and it will also allow you to run the Triad slipper system which makes down to a 69 tooth spur! Part number AV1020-TOP-KYO
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 10-14-2012, 08:21 PM   #1548
gelshocker's Avatar
Originally Posted by Kooz View Post
Not sure if this issue has been brought up yet because I don't want to read 103 pages. The steering Ackerman busted my first time out and shortened my maiden voyage! The part is on back order too! Just an FYI, the Associated Ackerman for B4.1 works fine. Just a temporary fix until parts become more available...
Kooz!
Can't believe no-one's selling this in carbon fiber yet, you'll make a killing before the alum K is released..
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-14-2012, 08:23 PM   #1549
rcfiend's Avatar
Trader Rating: 30 (100%+)
Hey guys what is the difference between the 2 ring and 3 ring axels. I traded awhile back for a RB5 and the guy included the aluminum hub carriers and they have the 3 ring axel stubs. Just trying to figur out which axels to use. Thx.
rcfiend is offline   Reply With Quote
Old 10-14-2012, 08:30 PM   #1550
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Run the 3 ring. Initially the RB5 had short arms, short CVDs and long axles. They came out with some revisions and eventually ended up with longer arms, longer CVDs and shorter axles which the 3 stripe represent.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-14-2012, 08:32 PM   #1551
whitrzac's Avatar
Trader Rating: 95 (100%+)
the 3 ring axles are the long ones, they require a 3mm shim. The 2 line axles require no shims.
whitrzac is offline   Reply With Quote
Old 10-14-2012, 08:41 PM   #1552
gelshocker's Avatar
Originally Posted by msandman View Post
I have had two race and practice sessions with RB6. I have messed with front shock location and flipping rear arms and running #2 hole. I keep going back to Std rear arms hole #3 and #3 hole on front shock tower. I keep going back to this setup, most consistent and the fastest lap times.
Just wish to say that having all 3 hole options on one arm is so much more convenient than seperate 521 and 521-1 rb5 arms, which essentially grew out of the ZX-5. So obvious and simple. Man, the rb5 looks so old..
Kyosho RT5 | RB6
Old 10-14-2012, 08:44 PM   #1553
RMKinWI's Avatar
Trader Rating: 15 (100%+)
Fresh build of my first 1/10 2wd Buggy.
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 10-14-2012, 09:25 PM   #1554
rcfiend's Avatar
I remember reading that there was a typo in the instructions for the thrust balls in the diff. Is it 7 or 8 balls?
Old 10-14-2012, 09:33 PM   #1555
Trader Rating: 138 (100%+)
The axles you are referring to are the ones that go on the 65.5 mm drive shafts that were introduced with the RB5 SP conversion.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-14-2012, 09:34 PM   #1556
8.
Old 10-14-2012, 09:36 PM   #1557
It looks old but the guys here in La La land still running it dominate in stock. But there fewer and fewer for them sue to the increase of people switching to the 6.
Old 10-14-2012, 09:39 PM   #1558
cnelson3's Avatar
Trader Rating: 66 (100%+)
Has anyone tried AKA Hexlite wheels? I bought a set and they dont fit the rear, the hole is bigger and the nut hole is not deep enough you cant get the wheel nut on more than a few threads. Hope that makes sense? The fronts fit. To bad I figured it out after I glued the tires!!
same thing with the JConcepts 12mm b4.1 wheels. I have used the serrated nuts and it just fits. standard nuts won't make it on.
cnelson3 is offline   Reply With Quote
Old 10-14-2012, 09:41 PM   #1559
rcfiend's Avatar
Originally Posted by jpcopeland1 View Post
8.
Thx.
Old 10-14-2012, 09:47 PM   #1560
gas1313's Avatar
Trader Rating: 18 (100%+)
What part in the steering keeps breaking! Just wanting to know before I run! Thanks if possible part # and does the gear diff fit this car.
gas1313 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Today 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
