    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-14-2012, 10:05 AM   #1516
Trader Rating: 137 (100%+)
Originally Posted by Kraig View Post
For confirmation, when you say longer ball studs you are talking about using ones that have a longer threaded part right?
Yes, just pick up a pack of long ball studs and be done with it. The short ones have a tendency to rip out. My car did it, 2 other friends cars did it (none of us crashed when it happened either). The black short ball studs don't screw in long enough, change them to the long ones and problems are gone. Also don't skimp on the grub (set) screws, use them where the manual tells you.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-14-2012, 10:06 AM   #1517
Originally Posted by rcfiend View Post
This may have been asked alreday, but I haven't seen it yet. Does the RB5 rear aluminum hub carriers work on the RB6 or do they have different ones?
Same hubs.
Old 10-14-2012, 10:09 AM   #1518
Originally Posted by Matt Trimmings View Post
Kevin, do you run the Orion wts battery or a full size? And if so have you added any of the weights to it?
I just picked up one of these packs but didn't have time to test with it yet. From what I know Chris Moore is using it and he loves it, using one aluminum weight in mid channel, actual battery pack part forward. Cant wait to tinker with getting the perfect balance with it. Plus in stock with that 90c he is ballistic.
Old 10-14-2012, 10:10 AM   #1519
So when are you going to ditch the AE and get an RB6?
Old 10-14-2012, 10:23 AM   #1520
Page 18 Sec. 17,
there seems to be a little play back & forth between rear arms & Susp. Holders @ 0.5mm
is this ok?
i used FF & FR (Alum 514 & 515).
Eric Summers is offline   Reply With Quote
Old 10-14-2012, 11:01 AM   #1521
gelshocker's Avatar
Originally Posted by jpcopeland1 View Post
If I can find mine, I'll post it. It is the addendum that tells you to shave down the turnbuckle that attaches to the servo horn. If yours clears without hitting anything like mine does, you don't need the sheet.
Thanks, I'll just make note of that, Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-14-2012, 11:09 AM   #1522
CanyonCarverR1's Avatar
Originally Posted by Eric Summers View Post
Page 18 Sec. 17,
is this ok?
I used a 0.2mm shim there
CanyonCarverR1 is offline   Reply With Quote
Old 10-14-2012, 11:10 AM   #1523
gas1313's Avatar
Trader Rating: 18 (100%+)
Default Gear diff
My friend just bought the car and was wondering if the gear diff fits it. Thanks
gas1313 is offline   Reply With Quote
Old 10-14-2012, 11:18 AM   #1524
RMKinWI's Avatar
Trader Rating: 15 (100%+)
What do I need to use a smaller spur? Seems Kyo doesnt make any smaller than stock spur 76. What gears are you guys running for Blinky 17.5?
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 10-14-2012, 11:22 AM   #1525
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You can use the AE or kimbrough gears (AE makes down to a 72, kimbrough a 69) you just need the gear and a set of AE slipper pads. Make sure if you get the kimbrough gear that its the one that accepts the AE pads.
Matt Trimmings is offline   Reply With Quote
Old 10-14-2012, 11:33 AM   #1526
metal or plastic?
i believe there is room looking top view for the 0.5mm, bottom view between looks slightly thinner.
and Thanx
ems
Old 10-14-2012, 11:36 AM   #1527
i read somewhere here (these threads are Flyn') spur 72 Losi (TLR3978) & 32 pinion or Kimbrough [KIM143] 70/33
ems
Old 10-14-2012, 12:05 PM   #1528
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
metal or plastic?
and Thanx
ems
.2 would be metal for sure. They make a combo pack that has a .3 .2 and .1 that go on by the CVDs and axles, and then smaller ones of the same size that are made for the smaller hinge pin holes. Very handy to have.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-14-2012, 12:24 PM   #1529
Weazsel's Avatar
Trader Rating: 58 (100%+)
metal or plastic?
and Thanx
ems
http://www.amainhobbies.com/product_...3x5mm-Shim-Set
"These are also used on the Ultima and Lazer family of vehicles to remove excess play in the suspension arms, and are also used in the servo saver assemblies. "
Always have a bag of these in the small parts box!
Michael Garramone
Serpent America l Desoto Racing l Pro-Line l Picco l Arrowmax l TQ Wire
Weazsel is offline   Reply With Quote
Old 10-14-2012, 12:32 PM   #1530
Thank you both
should they go in front of or behind, front or rear of arms?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
