ARRMA FURRY WITH CASTLE SIDEWINDER
LOOKING FOR WAYS TO KEEP CAR FROM SLIPPING AND SLIDDING , USING SUBCULTURES AND HAVE THE MOTOR AT 60% AND PUNCH CONTROL @ 50% ARE THERE ANY OTHER TRICKS
Motor size might be an issue..not sure what you have but castle is known for having a heavy punch since they are not sensored. Also track conditions could of course make a difference. If it's a loose track then its something that just will always be an issue.
sensored or unsensored
what would be the diff. if i had the sensored motor? what features does the sensored motor give you ?
Tech Legend
Trader Rating: 51 (100%+)
Put the punch control back to 0% so it has full punch. Set the start power to low and timing to lowest.
Now you will want to go into the Torque Control feature and get it setup. Now once you have it setup you can use this feature to take power away more smoothly. I used this feature a few times and once setup you can really control the power. U will need Castle link to to use that application.
