LiPo Charger Question
#16
Yes its more important that the amount of amps it can charge at.
Watt÷volt=amp. A charger that can charge at 10 amps won't be able to if it only has 50w of power. You can also use the equation in reverse amp×volt=watt, to figure out how much power you need. Lets say you have a 4s pack and you want to charge at 10amps 16.8v×10amps=168watts. But keep in mind that nothing is 100% efficient so buy one with a few more watts of power than you think you need.
#17
i use the venom pro and 2 venom 5000 2c lipos and i have not had any problems at all.
#18
I don't like chargers with built in power supplies. They seem a bit more fragile than plain DC chargers.
I like the Turnigy chargers. This one is actually better than my Hyperion:
http://www.hobbyking.com/hobbyking/s...ersion_2_.html
And the little 50w chargers are only about $25.
I use a Protech power supply at home. At outdoor tracks I prefer useing an extra G31 car battery with a 120/12v 6a float charger glued to it's top and plugged in.
#19
most chargers have 40-50 watts per output for a 5amp charge, so by your math, they could never actually charge at 5amps. even though they say they do. And these are 12 volt dc, not 16 right.
Just get the duratrax 235 or 245, you will be fine. Unless you really want to spend 200-300 on a charger.
#20
The Duratrax 235, 245 or the Eco one i linked earlier will fill your needs. Only get the 245 if you "need" / want to charge 2 packs at a time. Its the best duo AC/DC charger for the price.
#22
He asked for a AC/DC charger. Not a charge that he can hook to a 30amp external PS.
#23
If you are remotely serious about the hobby and electric racing, I'd suggest getting a real charger with an external power supply.
A good charger is one of those get what you pay for items where it is better to just pony up and do it right the first time instead of on the cheap.
A better charger will help your batteries last longer, charge faster, and have better balance.
You can get a top notch mid level charger and power supply for around $200 all in.
#24
I have a Junsi iCharger 306B that charges at up to 30A and 6S and is a 500W charger off 12V. It costs $160 but is probably the best money I ever spent. I bought a 30A Pyramid PSU for around $50 and have worked great for easily a year. I can charge 6000mAh in less than 15 minutes. It's awesome. Make sure to use batteries that can handle being charged that quickly. I use Thunder Power G6, RevTech, or Nanotechs.
#25
I went with the Hyperion 6060i, hopefully it was the right choice.
#27
#28
Not everybody needs to spend $200 on a charger, though. Taking this hobby serious doesn't automatically equate to having to spend a ton of money. It's ridiculous to suggest so in a thread where the OP specifically requested a charger with a built-in power supply at a decent price.
A quality charger pays for itself in spades, just like a quality tool set, or top notch solder iron. Yes, you can spend less but if he isn't overly budget constrained he may be better off sucking it up and spending a little more now instead of trying to do it on the cheap. As his interest in the hobby increases, he can then grow into the charger's capabilities instead of having to replace the charger, just because the cheap one isn't capable of keeping up with his needs.
