TLR 22SCT Thread (Check First Page for FAQ & INFO)
#2596
[QUOTE=tipperjackson;11189016]I've just become very interested in the Avid clutch. How easy is it to switch between spur sizes with the Avid setup? I switch from 17.5 to Mod quite often.
#2597
This adds no value to the thread, but this 22 platform is the first that I can honestly say, may just pull me away from AE.
Since 92 I have only bought 2 non AE rc's, and regretted it. The build quality, components and thought that was put in to the 22 looks incredible - time to get off the soap box and hopefully will find someone to let me take one for a spin at the lhs.
#2599
BTW ask someone to let you drive thiers. I let poeple drive mine at the track.
#2600
[QUOTE=tipperjackson;11189016]ill back that one up also...both of us were running on the same track, small tight track. was running consistant upper 17 second laps installed the avid slipper and ran consistant lower 17's to high 16's with a track fast lap of 16.6 of the night....
#2603
raced my truck tonight at wc/rc and with the stock springs in the rear my truck kept wanting to over-rotate so I swapped to white rears from a 22T and the car felt way more locked in, I am still slow but the truck felt so much better. Now I will continue to make small changes and practice until I feel dialed with the truck
#2606
To calculate the FDR the formula is:
spur# divided by pinion# = sum multiplied by trans ratio
(The trans ratio for the 22-SCT is 2.43)
The FDR of the 86/18 combo is 11.61
below are FDRs with 84 spur combos:
84/19 = 10.74 FDR
84/18 = 11.34 FDR
84/17 = 12.00 FDR
87 spur combos:
87/17 = 12.43
87/18 = 11.745
87/19 = 11.12
So, by looking at the above FDRs with the 84 spur, you can see that you will be above and below your target FDR of 11.61 with the 86/18 combo.
The higher the FDR # the more bottom end you will have....and more top end with a lower FDR.
You should be fine with the 84/18 combo. Check your temps often to make sure you don't overheat the motor. Try not to go higher than 160F to 165F max after 7min or however your longest main will be for. If temps are good and you feel you need more top end, move up to the 19 pinion. If you are running hot and or need more bottom end, go with the 87/18 combo.
I run an 86/18 combo with a Tekin 7.5 motor with 85% current limiting and temps were 155F after 15min+ of practice in my 22-SCT. Friend wouldn't give my truck back till the battery limit kicked in.
#2608
the avid 87 spur will rub the gear cover you have to use the 84
#2609
#2610
[QUOTE=vr6cj;11189043]
good to hear. I have one on my 22 too. Put that one on after this one.
http://www.avidrc.com/product/21/triad-slipper-clutch/
what kit do i need for the 22 sc and tooth on the big gear to get thanks
