Tuned Pipe ?
Tuned Pipe ?
I am looking to buy a a new pipe for my swift buggy (dented the stock one). I mainly run on a short to medium size course with friends but would like to get into real racing soon . I like the jammin I-II pipes with the reinforced stinger.Can someone tell me will a high torqe pipe kill my bottom end speed and vice-versa. I am not sure how much difference there is between the two.
from my understanding a shorter pipe is a torque pipe. better bottem end but top speed suffers a bit. better for short technical tracks where you need too get going fast. longer pipe means more top end but you lose a little on your get up and go. if you are new to 1/8th scale then it probably wouldnt make that much of a diff to you. as i am relatively new to the competitive 1/8th scale scene. in other words i am no where near as fast as some of the guys. i would reccomend something like the jammin pipe. it will fare better for you when the fast guys hit you when your trying to gwet out of the way. i should have got one of those as my 100 dollar rb pipe is now dented and had the stinger pushed flat against the pipe. still works but doesnt look as nice. also the reinforced stinger could save you a flame out and a losss of position and possible trophy or good finish
here is some general info I found on the net about tuned pipes.
Q. If 063 is for low end torque, and 086 is for the high end, clue me in on what the in-line restrictors that take the place of the coupler do-is this just a way to fine tune your pipe by lenght or hole diameter?
A. Since micro 2 stoke engines don't have any valves they use tuned pipes to simulate a valve. Each time the piston uncovers the exaust port the exaust pressure leaves the combustion chamber travels down the header into the pipe, through the pipe to the end of the pipe. Since the stinger is much smaller than the engine's exaust port then not all of the exaust pressure is relieved. This remaining exaust "pulse" then rebounds backward up through the pipe to the exaust port openning.
Timing is critical for max performance but in effect if everything is correct then that rebounding exaust pulse should reach the exaust port right about the same time as the piston is on it's way back up on it's compression stroke. When that happens then for a moment the rebound pressure is equal to the intake pressure so the exaust port simulates being closed. Now the critical part is if the engine is designed to have earlier or later compression timing then that exaust pulse will either be early or late. If it's early then the incomming fresh fuel/air charge will be short and some of the exuast gases will bounce back into the chamber. You will get a hotter less powerful power stroke. If the rebound pulse is late then some of the incomming charge will pass right through the engine and be wasted and the combustion chamber will be overly cooled by too much new fuel and no preburned fuel to help pre-heat the next charge.
Again, timing is critical to get maximum performance. Any micro engine will run with any pipe or muffler. Or even without one. But they will NOT run correctly or make power well.
So, if you have an engine that is designed to make it's max power in the topend range and you stick a lowend pipe on it then the rebounding pressure pulse is going to be late and out of time when the engine gets up into the high rpm range. Yet since the engine is designed for topend performance then a lowend pipe will not change the natural design of the engine. The engine will tend to always run rich on the topend so you lean it out. That improves the bottom end which gives the impression of improved performance. But the engine will not be making it's peak power ever.
As for the pipe shape. Yes the shape of the "convergance cone and the far end and the "divergance" cone and the near end (the header outlet is the referance point) has a marked affect on the amount of pressure that the return pulse generates. But again you really want to try to enhance the strongest points of the engine and then gear to the engine. Often if you are unlucky you may have to try 4-5 different pipes to find the one that makes the most of the engine. If you are real lucky you run into someone that has already found the optimum combo for your brand of engine and they save you a lot of trial and error. Or you pick a brand that has a matched combo already like OS or RB.
A2. The 'suggested' perfomance of a given pipe is just a general guildline. It's not set in stone. Even within a give pipe there are single chamber, duel chamber and baffled or non baffled variations. You could have 4 versions of a .053 pipe and each will have different charictaistics. The biggest and most common mistake that folks make about pipes is thinking that a given pipe will change the performace curve of a given engine. Sadly they are right in the wrong direction.
Any given engine has it's own performance curves. Some engines are lowend and some are highend. Some are in between there somewhere. Generally a 3-4 port engine will be a lowend, high torque engine. An 8-11 port engine will generally be a highend low torque engine. "torque" always refering to the bottom end. Where the problems come in is most
continued.
rookies believe that if they are suffering lowend performance with their engine then putting a "lowend" pipe on will fix it. Wrong. Putting a lowend pipe on a highend engine just chokes the highend range of the engines powerband. So now you have an engine that stinks all around. Many will argue with that remark stating, "I put a .*** on my engine and it really made it come alive!" Usually what they don't say is 'after I retuned the engine to run with the pipe I stuck on it'.
Proper way of matching a pipe/engine is to choose a pipe that makes the most of what the engine has to offer. Highend engine/ highend pipe. Lowend engine/lowend pipe. Match the pipe to the engine so that the engine makes the greatest power in it's natural power band. Once you've have done that then adjust the clutchs and gearing to take full advantage of the full power of the engine.
Don't try to MAKE the engine fit the clutch/gearing of the vehical.
Thanks for all the good info . I have a sh .21 that came with my swift buggy, but don't know how many ports or much of anything else about it .can't find anything online. Any info someone could give would be helpful so I could pic the right pipe. thanks
The JP-1 and JP-2 are going to work great on that motor. They're very tough and worth the money, and only at a competitive level of racing is engine/pipe matching going to make a big enough difference to matter.
Just find one you like
Quick fix for dented pipes
Quick fix for dented pipes. I don't know if anyone has ever tried this r/c but I have on a two stroke m/c pipe that was dented. Fill the dented pipe with water, and seal it off trapping the water inside. Place the dented pipe in the freezer over night. The water will expand when it freezes, and push the dent out from the inside. Take the pipe out and let the ice thaw out. Should work, and possibly save you having to buy a new pipe.
