Track Building Help...
i appologize if this is the wrong section
ok if you have any experience in track building heres my question
im doing a back yard track in so cal, my ground space is 50x80
i got 2 dumptruck and trailers full of sifted red clay
i put a flat base and started buildling the track on top of it but i cant keep the ground from cracking i can pack it and roll it a million times and the second i water it and it starts to dry the top layer crackes...
and about an inch under the top layer its just powder and this is been an on going battle for a week now ive tried different methods online of what people say to do and nothing worked if you have any suggestions any help would be great...
thanks
thanks
thanks
thanks
cracking is gonna happen i mean as long as its not huge cracks that are completely messing up your car ive seen cracking on all tracks ive been too, and in the outdoors its gonna happen more often. im not totally sure if there's a way to stop it but im sure there will be other people that post on this thread
You should check out socal-rc.com alot of people there do backyard tracks.
Try to get the water to penetrate deeper into the clay. That is why it is dry underneath. Water right before sunset, it gives the water time to sink in vs evaporate if it is hot out. Also try covering areas after watering to keep the moisture in the track to get it to soak in more. Sometimes covering after you compact everything and slowing the drying will help with the cracking but not always. The cracking is from the dirt shrinking as it dries.
cracks are going to happen, just repair them as they need it, small cracks wont do any harm, fix the ones that get bigger.
thanks
thanks
Here's what you need to do. Take 4 2x4's and drive nails, screws down the middle of the boards about 2" apart, then take old garden hose and ziptie, bolt, etc. the boards to the garden hose.
You will be pulling the garden hose with the boards attached width wise. Kinda like a ladder would be. Can you picture what I'm describing?
What is happening is the water is not getting down under the top layer of clay. The nails in the boards will score the surface enough to allow water to penetrate deeper. Using this contraption will allow faster coverage of the track. Usually this is pulled by a golf cart or lawnmower...you can pull it yourself. You might need to add some weight to the boards if it doesn't dig in enough.
Keep in mind a long light soak is better than dowsing the track with a ton of water. Just like a long light rain is better than a quick downpour.
Cracks will happen regardless especially if your the only one running on it. Maybe invite friends over and get a good groove built in after you do the scoring and watering.
my LHS looks up videos on youtube and just copies parts of different tracks
