Old 02-09-2005, 01:27 AM   #1
vti-chris's Avatar
Default Oiling all the joints??
Is it OK if i put oil on the joints of the suspension, steerenig, and everything that "moves"?
vti-chris is offline   Reply With Quote
Old 02-09-2005, 04:13 AM   #2
oople's Avatar
erm, pretty much no, dont oil anything.. oil the ballraces but do it out of the car and dont leave oil all over them. just inside.
oople is offline   Reply With Quote
Old 02-10-2005, 02:54 PM   #3
edseb's Avatar
No. The oil will make dirt stick, and make a mess in the long run. If it is a well designed car, it should have bearings, or other form of movement that is free of binding.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 02-11-2005, 04:04 AM   #4
Dear Chris,
The only things that need to be oiled are the ball bearings. Give em a good blast with a motor spray and add a few drops of trinity bearing oil. Make sure you clean your wheel bearings, your servo saver bearings and most of all your clutchbell bearings. Every other point in the car should work freely if you just give it a thorough clean.
1/8 buggies are tough machines that can do well even with stuck bearings. It is that preparation that gives you that little bit of extra you need to stand up from the crowd.
(That goes to another post of yours too)
Kyosho Evolva M3 / Kyosho Lazer ZX-5 SP / Xray T3
aantonis is offline   Reply With Quote
Question about oiling air filters Darth Smoke Nitro Off-Road 6 06-10-2008 01:54 AM
oiling shocks BSS07 Electric Off-Road 5 04-29-2008 07:50 AM
Shock oiling questions PSiDAWD Rookie Zone 4 03-30-2006 05:53 AM
Not oiling your balls...... Mabuchi540 Electric On-Road 10 08-15-2004 02:22 PM
Oiling bearings g_bruin Electric On-Road 14 06-16-2003 04:32 AM
SEO by vBSEO 3.5.0
