Shock O-Rings keep falling off. (Leaking Problems)
#16
Any1?
#18
A front and rear shock? Weird....I'm pretty sure that these are front shocks, it said when i bought em and i don't have any other castor shocks...
#21
Yeah, can't tell from your pic cuz of the shock boot and the uneven tops... but your lining up the bottom, not the top.
The shafts may be a different length or the thread length is different between the two shafts allowing the shock end to be threaded further up the shaft length on one side.
#25
Sorry I don't.
Do you guys think it could also be the ball ends? My dad changed the position of the ball ends and now the shocks are even. But i still don't get that one has more thread than the other.
#26
Looks like the top rings are identical in the front shocks. Not the best angle in their picture, but you can see that the top ring that the shock height clips push up against are the same.
Referring to the link below..
http://casterracingusa.com/product.php?productid=398
#28
Your right, they are way different. Can't believe i didnt notice this when i got em.
#29
So i went to the track today, and all was well. Until that same shock started leaking again. My other front shock had the same setup as that shock did and it did very well! No Leaks, No problems. When i rebuilt the shock a few days ago, i noticed that the O-Ring Chamber (I don't know what to call it lol) on the shock that was ok was longer than the shock that leaked. I think this might of caused it. I hope Caster has a warranty for this
