Tire Balanceing
#16
Thanks, is there any benefit to tape the inserts on the rims to avoid them spinning?
I need to choose one, do you guys have any preference between the design with and without the bearings?
#17
I would imagine that the extra weight of the tape introduced to your rotational mass would be far more detrimental. It's SO easy to balance, and takes SO little time, I would just check balance with some kind of consistent frequency. I use the du-bro prop balancer, right out of the package, and have zero issues. all you need is some non-hardening clay and you're set.
#18
Thanks , I don't think I'll buy one finally... I'll build it
http://www.rctech.net/forum/nitro-of...check-out.html
