What esc motor combo are ppl running in 1/8 buggy >
Old 04-17-2012, 09:14 AM
  #16
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
Originally Posted by midwestcajun
from what I have heard...yes. I'm no expert and have never been to the factory but the rumor is that the HW is an Orion knock off. They look exactly the same and comparing the two physically it would seem so. Not 100% on the hardware internally but others say that they are equal. They have the exact same interface on the lcd programming box just different stickers. I've heard great things about the Tekin combo as well. The customer service with Tekin is going to be highly superior to HW....but at $80 a pop if my ESC fry's then it will just be a replacement purchase instead of sending it back...but i've seen more Tekins melt than HW's so I'm hoping that won't be an issue...we shall see.
lol, well i wouldnt say that a HW is a Orion knockoff since HW makes the Orion esc for Orion. I know they do differ a bit internally comparing the 2 but from what i have heard hobbywing makes it for Orion to there specs. I have have run both and cannot tell even a slightest difference. With the orion you are paying for the name, little beefier internals, and a couple nice added features externally ( capacitor cover, switch, etc).
+1 to Tekins customer service, very hard to beat. Agreed 100% on even if you were to have an issue with HW, for the price it still a great buy.
ovalracer1m is offline
Old 04-17-2012, 09:18 AM
  #17
midwestcajun's Avatar
The running joke question is "How's the Blue Orion doing?"
midwestcajun is offline
Old 04-17-2012, 09:45 AM
  #18
Just got a text from a buddy and his HW Xerun just came in. Ordered it from..
http://www.rcecho.com/XERUN-Competit...-150A-ESC.html
Took less than 2 weeks to arrive and it looks like they have some left.
Old 04-17-2012, 09:52 AM
  #19
Trader Rating: 114 (100%+)
I run a Tekin RX8 and 1700kv in my E buggy with a 4S 6000mah Xcelorin pack and I really like the power output. It has more than enough power and speed for both the indoor carpet tracks as well as the outdoor dirt tracks I race on.
C.Capelo is offline
Old 04-17-2012, 10:06 AM
  #20
BlueGlowBoy's Avatar
I've got an LRP iX8 and 1800kv Dynamic 8 on it's way for mine. Was running all Tekin stuff before, then tried some LRP 1/10th speedos and loved them....looking forward to testing out the iX8
BlueGlowBoy is offline
Old 04-17-2012, 10:17 AM
  #21
Originally Posted by jy144
Might sound dumb but what's the diff between higher and lower kv
Originally Posted by TY@TEAMTEKIN
kV means RPM per volt, so the higher the kV, the faster the motor.
The flip side to that, the lower the kv, the more torque the motor has.
you can take a lower kv motor and gear it up, or a higher kv motor and gear it down to achieve similar results
Also, you can take a really low kv motor, and use 6S to achieve similar RPM to a higher kv motor on 4S.
2000kv @ 14.8v = 29600 RPM
1300kv @ 22.2v = 28860 RPM
What this can achieve is longer runtimes (and i THINK less heat, but can't remember) out of the same capacity battery.
(Yes, I know that isn't the WHOLE story, but it's the basics)
But again, most tracks want you to run 4S.
1800-2000kv seems to be the range you should be looking for. Works well for me on a 80x200ft track with fast straights, big jumps and a hard-packed often slightly grooved surface.
Old 04-17-2012, 10:40 AM
  #22
Pulse_'s Avatar
I tested -in order of appearence
2200kv 4s castle
2050kv 4s tekin
1350kv 6s tekin
1400kv 6s tekin
4000kv 2s tekin
went back to 1400kv 6s tekin
1645kv 4s leopard -> sold it two weeks after
1400kv 5s tekin
stayed with this setup that I run on my two converted buggies (JQ and Durango)
For the guys wondering why I'm not running 6s with the 1400kv -> because tracks are smaller here and I'm faster and more consistent in 5s. A 1400kv 5S setup runs cooler and has a little more top end than a 1700kv in 4s. An other point is that I drive indoors too. My laptimer and my temp gauge decide what setup I drive
Pulse_ is offline
Old 04-17-2012, 11:06 AM
  #23
Tekin rx8/T8 1900-2050kv
sirio76 is offline
Old 04-17-2012, 11:25 AM
  #24
youwish16's Avatar
Trader Rating: 21 (100%+)
Speed Passion Silver Arrow ESC with Tekin 2050kv motor on 4s(2 x 2s lipos)
youwish16 is offline
Old 04-17-2012, 01:07 PM
  #25
+1
wade0246 is offline
Old 04-17-2012, 01:28 PM
  #26
Teammoose's Avatar
Trader Rating: 20 (100%+)
rx8/1900kv in one
mmm/tekin 1700 in other
4s both
Teammoose is offline
Old 04-17-2012, 01:43 PM
  #27
RX8/1900kv, real smooth and easily tuned with hotwire. Tekin support is also top notch, and how many other manufacturers take the time to go onto forums like RC Tech and oOple to help solve problems? For me that is a big plus.
Badger5 is offline
Old 04-17-2012, 02:18 PM
  #28
DBL15's Avatar
+1 same for me too great product support and helping out on set ups etc is 2nd to noone in this business i feel
DEX408 RX8 & Tekin 1900kv with 21 pinon and Hitech servo
DBL15 is offline
Old 04-17-2012, 02:27 PM
  #29
this is actually a common mis-conception, lower kv doesn't always mean more torque. on similar motors with the same amount of poles on the rotor and same amount of magnets in the stators high kv will yield more torque. the reason is in order to get the higher kv they put less windings in the stator which lowers the resistance or more specifically ohm load of the motor allowing more electricity to flow through the stator creating stornger magnetic fields that push and pull the rotor which in turns yields more torque. really the only time less kv means more torque is when you go from like a 2 pole to a 4 pole motor, or adding more magnets to the stator or just going to a bigger motor.
AWDdude is offline
  #30
R/C Tech Elite Member
blade329's Avatar
Got a new buggy just curious to what people are using
Ve8 = RX8/T8 1900kv/2 x 2S
8ight = MMM/T8 1900kv/4S
blade329 is offline
