Green slime on 1/8 scale diff o-rings
I have a question is it ok to use green slime on the o-rings do you have to use only a little of it to prevent it from mixing with the diff oil ?
You can use it, better than nothing I suppose. But, I would highly recommend a thicker, HD grease, such as Mobil1 Synth red, or Maxima. I use a lot and grease everything...
+ YouTube Video | |
Green slime is very good for this. It's not as thick but it doesn't react with the silicone like some petro greases can. I use another suspension grease on my diffs and it works very well.
The heavier stuff like Mobil is probably better for the outdrive/case bushing surface (the grease's real function) but I have never had a problem with the suspension stuff. It's still there when I change out the diff fluid every few races.
Well i used the Mobil 1 red grease on the O-rings a decent amount of it i hope its fine i used it on one diff and added the diff oil ?
Lots of guys use Mobil 1, I've never heard of anyone having any problems with it. Seems to work very well and you can't beat the price.
I just mentioned the compatibility because Mobil 1 works great, the waterproof marine grease 3 spots down on the shelf might not.
