why did battery wires melt off?
I was increasing the timing on my motor by slight increments (was only at about 10 degrees from the stock 13 deg. and went only two laps) when I landed pretty hard off a jump and the car died. I looked under the shell and the battery wires were mostly free from the esc posts and looked as if the solder melted.
Neither of the electronics were ran long enough to get too hot and werent hot upon feel. Would an old connection hold enough impurities to create a high resistivity to create the heat? None of the other connections were getting hot or soft.
I think you experienced a perfect storm type scenario.
You probably had a a cold solder joint on that part of the ESC , a cold joint can/will have higer resistance than the wire , and as you increased timing you started drawing more current through the cold joint .
More current means more heat at that cold joint till it failed . Or you might have had a current spike during the crash , like when you hit the gas trying to save it and the wheels hit the dirt and suddenly cause a load on the motor.
thanks for the support
