Like Tree2Likes
Old 01-04-2016, 07:38 AM   #1201
Laker67's Avatar
Trader Rating: 61 (100%+)
Originally Posted by JRSlash View Post
does any body try a T5M body on their st210? The new JConcepts Hi-Flow for the T5M looks like it will fit the Durango.
I thought the same thing, I've been using the RT6 MM Jconcepts body on my truck and it works great. I'm not sure how different the T5M mounts are to the RT6 but if you buy one let us know.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 01-04-2016, 11:42 AM   #1202
JRSlash's Avatar
I looked earlier today at Big Squid news and saw the Jcon body for the T5M and I swear it looks like it will fit the Durango just by judging at the picture. That's why I asked. Will be hard for me to buy a $30 body that I don't know if it will fit. I would be upset if $30 go down to waste like that.
JRSlash is offline   Reply With Quote
Old 02-14-2016, 06:51 PM   #1203
Pekr.da.skurl's Avatar
FYI TOWER HOBBIES status for the Dest210 body changed to May. I'm a bit surprised sense they don;t make em anymore
Pekr.da.skurl is offline   Reply With Quote
Old 02-14-2016, 08:15 PM   #1204
Kremzeek's Avatar
I don't want to read too much into it, but hopefully that means we'll see a v2.
Kremzeek is offline   Reply With Quote
Old 02-14-2016, 08:54 PM   #1205
Agreed.
Old 02-21-2016, 09:00 AM   #1206
And now back to order pending. Lovely
Old 02-22-2016, 09:10 PM   #1207
dirtracer4's Avatar
Trader Rating: 16 (100%+)
I'm using the mm rt6 jconcepts body also.
dirtracer4 is offline   Reply With Quote
Old 02-26-2016, 06:08 PM   #1208
Devin's Avatar
Default Drivetrain?
Anyone ever have an issue with their truck having a lag after you gun it? Coming out of corners it seems to take a second for my truck to spool up before it picks up speed. The truck is pretty new. I tried messing with the slipper, if anything it's tight. Checked the punch on the ESC. Wonder if anyone has an idea.
Running 81/29 I think on a 13.5. The gearing is pretty cold, 130 roughly. My DEX and DESC are geared similarly with the identical motor and they giddy up.
Devin is offline   Reply With Quote
Old 03-02-2016, 12:35 PM   #1209
Are you running gear or ball diff? If ball diff it may be sipping? Maybe something binding in the gearbox? Or at the outer hubs. Pull some things apart and see if the hubs spin freely and you can spin the gearbox without motor.... Might be a bad bearing somewhere
Good luck.
WallyRC is offline   Reply With Quote
Old 03-04-2016, 05:07 AM   #1210
Conversation kit for the dest210 for medium to high grip tracks
From mr'o'racing the TD2-4T
Mroracing.Weekly.com
mroracing is offline   Reply With Quote
Old 04-03-2016, 09:36 AM   #1211
Default Sideway shorty!!!
Did the sideways shorty mod on my DEST, and what a difference. Handled so much better. Rear end was only loose when I gave it too much throttle. Playing around with rear gear diff. Went to 4 planetary metal gears and 3000 weight, was 7000. Don't know if improvement was battery or oil change. Or both?? I used a B5 battery brace by Jconcepts and two turnbuckles. Gonna try a ball diff next time to see if there is a big difference. Need a touch more steering with corner entry. I took front weight out, may put back in. I am running mid motor 3 gear. Indoor dirt/clay. Using AKA Chainlinks. Some running slicks.
Old 04-23-2016, 03:20 PM   #1212
Where can I get information on the battery mod?
Old 04-23-2016, 04:56 PM   #1213
Pittster's Avatar
There is a bit of info in the Dex210 thread about it.
You Basically dremel the supports in the middle of the chassis add Turnbuckles for rigidity and double side tape the battery down.
As per pic
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 04-23-2016, 05:42 PM   #1214
Devin's Avatar
Good luck.
Gear diff
5000 weight oil
4 planetary gears
Seems to spin free.
Slippers pads are fresh.
Old 04-23-2016, 07:21 PM   #1215
Thanks for the info.. Im trying to update my truck to the long outdrive cups. It seems like the ridge the bearing ride on the diff is a bit wider. When I tighted the trans back up everything inside gets tight as a bitch. I have to back off all the transmission bolts way way off. Anyone shed some light on this problem. I searched but couldn't find anyone else having the same problem. Thanks
Team Durango DESC410R Thread KostaG Electric Off-Road 12281 Yesterday 09:10 AM
