Like Tree2Likes
Old 11-11-2015, 10:25 AM   #1186
Any one think team durango going to come out with new dest210 r or should I just get a used one and find lots of parts ?
marco m is offline   Reply With Quote
Old 11-11-2015, 11:27 AM   #1187
8ight-e's Avatar
Trader Rating: 57 (100%+)
At this point I wouldn't expect a v2 of the SCT.. other than changing a-arms or tower height like they did w/ the buggy you can consider the B-Type parts loaded in a v2 of the desc210. Honestly at this point it's still my favorite sct I've owned,, I did just install a "plan B" chassis on it though.. that is pretty slick for sure.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 11-11-2015, 11:40 AM   #1188
Kremzeek's Avatar
There's supposedly a DEX210v3 coming out. If we did see a new DEST, it would probably come some time after that. However, I would not hold my breath.
Kremzeek is offline   Reply With Quote
Old 11-11-2015, 11:44 AM   #1189
Default Running shorty pack?
8ight,
You running shorty in the plan B Chasis. Whats your setup: Mm3,4? I was thinking of going that route? I run indoor only.
WallyRC is offline   Reply With Quote
Old 11-11-2015, 02:59 PM   #1190
8ight-e's Avatar
Originally Posted by WallyRC View Post
8ight,
Yes to the shorty.. not sure about the RM or MM I just recently got it doing some more testing. I run a mix of indoor turn and for outdoor dirt will be doing some indoor dirt w/ a new track so.. my RM is soo fast indoors it's tough to want to move it to a MM setup and loose the traction I get outdoors or on the indoor dirt. I may still give it a shot and if I did I would start w/ mm4 at first, im not trying to shave weight and no super high bite tracks to worry about that I race on a regular basis.
Tekno ET48, EB48.2
Old 11-23-2015, 06:46 PM   #1191
303slowdown's Avatar
Trader Rating: 21 (100%+)
For anyone still running this truck, this is the setup I run and it works really well for me. Use at your own risk.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-22-2015, 12:56 PM   #1192
JRSlash's Avatar
Hey, I just picked one of these trucks as my first stadium truck. Question is: What parts are the ones that are more prone to break on this truck? I will be picking up some spares for it. thanks.
JRSlash is offline   Reply With Quote
Old 12-22-2015, 02:28 PM   #1193
Pittster's Avatar
Rear Arms x5, Front body mounts.
Boil rear arms for 40min helps them live longer but I am averaging a broken arm every 1-2 hours of run time. I have Alloy front and rear pivot block in the rear end so the arm breaks every time.
If you run the kit Plastic one they can give out instead of the arms.
I always keep 3 sets of rear arms on standby and replace them even if they look OK before a big event.
apart from that truck is awesome
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 12-23-2015, 11:27 AM   #1194
JRSlash's Avatar
Awesome, Thank You. Looking forward to put this truck on the track.
Old 12-25-2015, 10:45 PM   #1195
dirtracer4's Avatar
Trader Rating: 16 (100%+)
Brian, I just built a DEST using a plan b chassis. I have been using one of his DESC chassis and decided to try ST. Have you had any time for a MM4 setup using this chassis? Thanks
dirtracer4 is offline   Reply With Quote
Old 12-31-2015, 09:46 AM   #1196
JR, make sure you add the crush tubes (TDR 712003) and maybe a 0.2 or 0.3 shim to the front axels so when you tighten down the wheel nuts you get no binding. The rear may need a 0.2 or 0.3 as well. Look at the first page of the DESC210 thread. It explains all the little nuisances to run smooth. I agree with the above. I have only broken rear arms. Good luck.
Old 12-31-2015, 10:56 AM   #1197
Dirt racer,
Gives us a good update once you get a chance to run the DEST with the plan B. Real curious how it handles.
Old 12-31-2015, 12:39 PM   #1198
Boil for 40 minutes??? I been boiling but I do 3 to 4 minutes. Is that correct?
Old 01-04-2016, 06:43 AM   #1199
JRSlash's Avatar
well..., raced this weekend and the only things I broke was the spoiler which I am going to try the Jconcepts one and the chassis. I guess I needed the "b" type one which is on the way. Other than that I love this truck. I broke the chassis during the 2nd qualifier and still made the 3rd and made A main with the front clip been held by the body of the truck. Also come to find after the race that the person that had it before me had the shock pistons all mixed up. Don't know how much that affected my suspension but it was wrong anyways. Cant wait to get it all put together correctly and give it a try.
Old 01-04-2016, 06:46 AM   #1200
JRSlash's Avatar
does any body try a T5M body on their st210? The new JConcepts Hi-Flow for the T5M looks like it will fit the Durango.
Team Durango DESC410R Thread KostaG Electric Off-Road 12280 08-11-2017 07:22 AM
