Like Tree2Likes
Old 07-25-2015, 01:37 AM   #1171
You can use the front 12mm hex from the Schumacher K1 Aero,
And a few pages back someone found a body that fits well also.
I like my DEST210, but there arent many other stadium trucks in my area to kompare it with.
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 08-03-2015, 08:44 PM   #1172
Originally Posted by 10pcNugget View Post
EDIT* has anyone actually found the type "b" chassis to be a little bit stronger?
I came up short of a big tripple at our track and hit nose first and broke the front end of the car, were the front bulk head attached, right where the kick up is.
Sumo Racing makes a front rear skid plate to strengthen the front and rear of the chassis. I paid 18.99 for them as a set.
windylee is offline   Reply With Quote
Old 08-30-2015, 04:09 PM   #1173
Well I guess that answers some questions. The DEST210R is no longer listed on Durango's website and the RTR is shown as no longer manufactured. Either the v2 is on the way, which I personally doubt, or the ST has been discontinued outright.
blankenj99 is offline   Reply With Quote
Old 08-31-2015, 08:19 PM   #1174
Kremzeek's Avatar
It's under discontinued now. I guess its good that they finally did something, even if it was to discontinue the truck instead of leaving it in limbo.
Kremzeek is online now   Reply With Quote
Old 09-09-2015, 09:02 PM   #1175
Devin's Avatar
That's too bad. I am quite fond of mine and I like keeping everything to one line of vehicles.
Devin is offline   Reply With Quote
Old 09-16-2015, 05:05 PM   #1176
INFERN0's Avatar
OK fellow DEST210 owners, after some searching and fitting I have found the body that best fits this truck since the stock body is nowhere to be found.
I hope these upload. The front mount must be re-drilled higher on the tower so it sits against the shock mount screws when the shocks are on the inner most holes on top. The rear needs no mod.
Team Durango DEST210R thread-dest2101.jpg   Team Durango DEST210R thread-dest2102.jpg
Proudly driving for Kyosho America, Team Maclan and RC Pitstop
INFERN0 is offline   Reply With Quote
Old 09-16-2015, 05:37 PM   #1177
And that body is........
Old 09-16-2015, 05:45 PM   #1178
INFERN0's Avatar
I put the body tag in the picture with part number but it's the JConcepts Finisher body for the Kyosho RT6 MM only part number 0269
Old 09-16-2015, 06:45 PM   #1179
I see it now. Every time I tried to move the enlarged pic it closed. Tks
Old 09-27-2015, 11:19 PM   #1180
Default Don't give up hope!!
Check out EXOTEK description under their new mid motor bulkhead for the 210 line ....
It read DESC210v1,v2 ( same for DEST). And v3 for the DEX. They seem to have a good relationship with Durango, so let's hope something is coming soon!!
WallyRC is offline   Reply With Quote
Old 09-27-2015, 11:22 PM   #1181
Default Great job!!
I just did something similar with the bulldog body by proline. The jconcepts looks like the rear fits much better though. I had to take the heat gun to mine to make room for the rear tower and shocks, but the front fit great!! I will try and post pics later.
Old 10-18-2015, 01:26 PM   #1182
Taz_S's Avatar
When you go to the 12mm cov. What wheels do you use?
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 10-28-2015, 10:50 PM   #1183
klowne's Avatar
If a mold of the original body that was produced for the kit, how much of an interest for it would there be? Not wanting to make a profit but at least have a viable way for people that want a new body able to get it.
klowne is offline   Reply With Quote
Old 11-01-2015, 06:45 PM   #1184
Default Astro turf setup
Does any one have a good Astro turf setup? Also what tire should I be using ??
Team Durango USA
OS Engines
Iggy 102 is offline   Reply With Quote
Old 11-04-2015, 02:22 PM   #1185
Default Check DESC
For a starting point I would look at Petitrc and look for a good DESC setup and then step down a spring or two and try and balance from there. I would think light red/ black rear and Bordeaux / orange front would be a good place to start. Go with gear diff in 7000 range for oil. Tires I have no idea. Check with guys that are fast down at the track. Hope this helps. Read up on the thread "tuning with camber links". Fred Swain has a to of good info there.
Team Durango DESC410R Thread KostaG Electric Off-Road 12281 08-18-2017 09:10 AM
