Like Tree2Likes
Old 06-15-2015, 08:07 AM   #1141
I'm putting a DEST210R together for our super stock class. 13.5T motor, blinky mode ESC. What is a good starting point for the pinion gear?
Team Driver
ThumbRC.com - Offroad RC Track in Michigan
LC-Racing.net - #1 LC parts source in the USA
https://www.facebook.com/groups/124620841371685/ - Rock racing forum
racer726 is offline   Reply With Quote
Old 06-15-2015, 01:55 PM   #1142
Laker67's Avatar
Trader Rating: 61 (100%+)
It really depends on the motor, I have been able to gear my D4 Motors a lot higher then my LRP motors. But I think right now for 13.5 I'm running 22/81 and on dirt she comes off at about 155*
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 06-15-2015, 08:35 PM   #1143
Kremzeek's Avatar
Here's a very useful web page:
http://www.durangofansite.com/main.p...0&page=gearing
I'm not sure if this would fit, but if you're using the stock 87T spur, the 26T pinion would be a good start. Otherwise a 81T spur and 24T pinion would work.
Kremzeek is offline   Reply With Quote
Old 06-26-2015, 09:09 AM   #1144
First stadium truck build, went very smooth. Cant wait for first race!
10pcNugget is offline   Reply With Quote
Old 06-27-2015, 03:37 PM   #1145
Kremzeek's Avatar
What tires are those?
Old 06-27-2015, 03:43 PM   #1146
Proline Prime's
Old 06-27-2015, 06:09 PM   #1147
In addition to my original post, for anyone who is interested
Set up-
MM3 gear, 87t spur, 20t pinion
SMC 120 amp esc, LRP x20 8.5t
Promatch 6500 mah 70c 2 cell
Protek 100ss servo
And of course airtronics receiver
Old 06-28-2015, 01:40 PM   #1148
Kremzeek's Avatar
Proline Prime's
You running on clay?
Old 06-28-2015, 05:01 PM   #1149
I've asked before but does anyone know of a good fitting replacement body for the dest210?
blankenj99 is offline   Reply With Quote
Old 06-29-2015, 08:05 AM   #1150
No i am not, just tryng some things out, usually run the same tire in super soft, but in the past i have noticed from using sauce "which you have to at local track to get any sort of traction" the tires ended up getting "too" soft if that makes sense... in return almost making drag on the vehicle.. so im trying to sauce up some clays and see how they compare, as of yesterday they seemed to hook up more and more after saucing them, still not there yet but im working on it.
EDIT* has anyone actually found the type "b" chassis to be a little bit stronger?
I came up short of a big tripple at our track and hit nose first and broke the front end of the car, were the front bulk head attached, right where the kick up is.
Old 06-29-2015, 06:32 PM   #1151
ekt
ekt's Avatar
The type B chassis types are a lot stronger than the originals.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 06-29-2015, 08:41 PM   #1152
Pittster's Avatar
Also keen to know about this anyone had any experience with different shells ?
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 06-29-2015, 09:28 PM   #1153
Yes, if you check a few pages back a guy got a ct4.2 /kyosho body to fit with minor mods, even has pictures, i put a t5m body on mine at the track and i could easly see it fitting, but under the same conditions as the above one, with minor modifications, mainly making room for the center brace on rear shock tower.
Old 06-30-2015, 10:31 AM   #1154
Kremzeek's Avatar
It looks like the stock body will be in stock again soon at Tower Hobbies. It's currently "Order Pending" so they should be available any day now.
Old 06-30-2015, 10:38 AM   #1155
Yeaaaahhh... About that. Tower has had that for months now i beleive.
Team Durango DESC410R Thread KostaG Electric Off-Road 12281 08-18-2017 09:10 AM
