Like Tree2Likes
Old 01-23-2015, 08:19 PM   #1096
Originally Posted by Kremzeek View Post
Those are Durango springs. Here's the complete chart:
http://www.team-durango.com/blog/201...spring-charts/
What sort of track are you running on? I run on carpet so my shock setups are probably going to be a lot different than those that run on dirt.
I am gonna run on a tight med. Traction track with a good size jump.
x195svt is offline   Reply With Quote
Old 01-25-2015, 01:57 PM   #1097
Default Online store
Hi! Will you recommend an Asian (HK,Chine,etc.) store that caries TD parts,please!
Thanks!
carpediem is offline   Reply With Quote
Old 01-31-2015, 02:58 PM   #1098
Trader Rating: 24 (100%+)
Guys,I put my DEST210 in the for sale section,interesteds please take a look....
Team Associated TC7.1/HW XR10 Stock Spec/HW Bandit 10.5T/Arrowmax LP 52000 7.6v
IVAN RM is offline   Reply With Quote
Old 02-05-2015, 05:35 PM   #1099
platgof's Avatar
I am going to get my Dest back up running again. I am installing a gear diff this time, with a 10.5 motor, and see how that works out. I will be using the plastic diff gears in it(moulded.) We don't have a class for it yet, but that is always subject to change.
platgof is offline   Reply With Quote
Old 02-10-2015, 07:22 PM   #1100
hey guys I just bought my first Durango...looking for a recommendation on a good setup sheet to start with for MM4 on a medium/high bite clay indoor track. Thanks
TLR 22 SCT2.0 TLR 8ight T 3.0 AE B5M blinky Durango DEST210r 7.5 VST2
barry1me is offline   Reply With Quote
Old 02-16-2015, 07:20 AM   #1101
can anyone tell me what the metal part equivalent for the kit RF suspension mounting, specifically #330341-3, the one that gives three degrees toe in and anti squat. My chassis is the old dest210r one. I think pre type B. Anything from Durango, RDR or whatever will be great. Thank you.
one-nil is offline   Reply With Quote
Old 02-16-2015, 07:06 PM   #1102
Kremzeek's Avatar
Something like this?
http://www.exotekracing.com/dex210-r...ith-shims-lrc/
or
http://www.team-durango.com/part-inf...artNo=TD330565
Kremzeek is offline   Reply With Quote
Old 02-17-2015, 05:19 PM   #1103
Kremzeek: Thank you!
Old 02-20-2015, 05:23 AM   #1104
Default chassis
Hi there! Does the DESC and DEST has the same chassis?
Old 02-20-2015, 05:50 AM   #1105
No, SC is longer
blankenj99 is offline   Reply With Quote
Old 02-20-2015, 06:01 AM   #1106
Tdub77 is offline   Reply With Quote
Old 02-20-2015, 06:33 AM   #1107
Trader Rating: 57 (100%+)
No. The SC chassis is a big longer and wider.
shagino is offline   Reply With Quote
Old 02-21-2015, 08:03 AM   #1108
Default Re: !
Tanks for reply! The reason I'm asking is Phat Bodies chassis hugging overbody for the Durango DESC210.
Do you think it will fit on DEST chassis?
Old 02-27-2015, 04:41 AM   #1109
La Placa's Avatar
I have built and rebuilt at least four different transmissions both mid and rear mount and have always had a tight spot when spinning the gears by hand. Has anyone had this issue and did you find a solution for it. I looked at all the gears and transmission cases and can't find anything.
La Placa is offline   Reply With Quote
Old 02-27-2015, 11:22 AM   #1110
Default Re: ?
Over tight diff case,perhaps.
Team Durango DESC410R Thread KostaG Electric Off-Road 12306 Yesterday 04:50 PM
