Like Tree2Likes
Old 12-09-2014, 04:02 PM   #1066
iDesign5's Avatar
Originally Posted by ekt View Post
Is it the kit version or rtr? The RTR version will need a couple small parts to be able to run MM4 but MM3 is no issues as long as you get all the parts that came in the box.
Its the kit. The only thing I think I might not get is the rear chassis brace that has the arch to cover the motor. I didn't know if there was anything else.
iDesign5 is offline   Reply With Quote
Old 12-09-2014, 06:38 PM   #1067
Kremzeek's Avatar
Originally Posted by Fast410 View Post
Anyone running the dest in mid motor version ?
I put one together and run it in 4gear mm have good steering and side bite in and out of corners , but suffer forward bite ..
I'm running 4 gear MM but on carpet so there's no lack of traction. What sort of track are you running on? What tires?
Kremzeek is offline   Reply With Quote
Old 12-09-2014, 07:57 PM   #1068
joeld2llio's Avatar
Running MM4 is the reason I got one. Cush setup on petitrc.com with stick battery all the way back feels pretty decent on my clay indoor tracks. I'm running m4 electrons.
joeld2llio is offline   Reply With Quote
Old 12-10-2014, 12:19 AM   #1069
iDesign5's Avatar
For MM4 AND RM4, is there a different gearbox case or just the different idlers and rotation? Sorry for probably obvious questions but like I said I am new to the Durango platform.
Old 12-10-2014, 03:08 AM   #1070
ekt
ekt's Avatar
All the different configurations use the same gear box, it's just the idlers and layshaft configuration that changes.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 12-10-2014, 04:53 AM   #1071
Fast410's Avatar
Trader Rating: 40 (100%+)
My son ran that set up when he had it in rm version . I built mine in mm4 to see if it was better than rear motor , and it is in the jumps and turns but the forward bite was not real good . I run a 6.5 motor if I ease in the throttle I'm ok but looking for more rear bite . I made a 48 gram weight for the back of it going to try that with diffrent shock settings. I'm happy with it for only 1 day on it .. Cush and Johnny 5 race at the Track I go to I know them . There set ups are usually on a good bite clay track. They don't run Durango anymore .
GRUDGE RACING $$ PROMOD KUSTOMZ real race car fabrication and custom painting -airbrushing CHICAGO WISEGUYS RACE CIRCUT-1/4 mile Door Slammers @ 200mph plus
Fast410 is offline   Reply With Quote
Old 12-11-2014, 06:03 PM   #1072
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
I run MM4 on indoor clay, dont really have issues with traction, mine still pulls wheelies once in a while if I come out of a corner hard. I had more issues trying to get it to steer, but I finally got it right. I run a D4 13.5 with the high torque rotor in mine, geared 75/26
Jeepy2013 is offline   Reply With Quote
Old 12-17-2014, 05:34 PM   #1073
Trader Rating: 110 (100%+)
Subscribe
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 12-19-2014, 10:21 AM   #1074
So I finally got around to working on a 12mm hex solution. I still have a few other ideas to adjust the final track widths front and rear...but here's an easy 12mm hex conversion that almost keeps stock track widths.
Rear- (needed: Dex210 axles, B4.2 rear clamping hexes, TLR 22t wheels)
Swap DEST210 axle for a Dex210 axle
Install Proline or JConcepts B4.2 rear clamping hexes using AE axle pins
Install TLR 22T wheels
net trackwidth change is -2mm per side
Front- (needed: B44.2 front clamping hexes, AE T4 wheels)
Pull stock axle
Put 3mm spacer on axle on reinstall through carrier (moving stock spacer from outside to inside of axle carrier)
Install B44.2 front clamping hexes, don't use axle pins...just tighten clamping hex
Install AE T4 wheels
net change in trackwidth is +1mm per side
Wanderer77 is offline   Reply With Quote
Old 12-21-2014, 09:16 AM   #1075
Kremzeek's Avatar
Raced indoor for the first time this season yesterday. Broke a rear arm in one of the qualifiers and stripped out the servo horn in the main. Still had a ton of fun.
Old 12-29-2014, 11:38 AM   #1076
wrong thread
Ahaynes is offline   Reply With Quote
Old 12-31-2014, 01:27 PM   #1077
Speedo711's Avatar
Smile Dest210
Just got mine finished
Built it up in mm4
Looking forward to racing it at the Mikes Rc World New Years Bash in Bellingham WA
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 01-08-2015, 12:39 PM   #1078
Laker67's Avatar
Trader Rating: 62 (100%+)
So I'm pretty amped up guys, I just stopped by my track to test fit my buddies RT6 mid motor body and I think I can make it work. I have to move the front body mounts up on the shock tower but I don't think it will be a big deal at all. I'll post up some pics when she is done.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 01-09-2015, 08:27 AM   #1079
Laker67's Avatar
So I got the body cut out last night and lined up on the truck. The only thing I had to do to make it work was move the front body mounts further up the shock tower. This meant re-drilling two new holes just under where the front shock mounts are. It will need something on the body to keep the shock tower from rubbing the paint off but other then that it went pretty well. The only thing I would change the next time I do a body would be to leave the sides a little bit longer until I get the body mounted and then trim to the same level as the bottom of the chassis. Right now its really close but you can see the back of the chassis if your looking for it.
Team Durango DEST210R thread-img_3998.jpg   Team Durango DEST210R thread-img_3999.jpg   Team Durango DEST210R thread-img_4002.jpg   Team Durango DEST210R thread-img_4003.jpg
Brian Jenkins
Old 01-11-2015, 02:25 PM   #1080
Kremzeek's Avatar
That body looks pretty good on there. Did you have to cut a hole so that the rear shock tower didn't hit?
Team Durango DESC410R Thread KostaG Electric Off-Road 12282 Yesterday 06:29 PM
