Like Tree2Likes
Old 10-17-2014, 09:18 PM   #1006
Kremzeek's Avatar
Originally Posted by Jeepy2013 View Post
Are you running a shorty or full size pack? I went to a shorty, all the way back as far as it would go, made a big difference. With a full size pack, even all the way back I was too nose heavy. My steering pushes now, but most of that is the crappy tires I'm using right now.
I'm running full size. I really didn't want to buy shorties for indoor but I may try one one and see if that helps.
Kremzeek is offline   Reply With Quote
Old 10-19-2014, 04:03 PM   #1007
joeld2llio's Avatar
DEST210R built, electronics installed, tires glued. Dying to try it but there isn't a 7mm wrench or socket in the house that will fit in the deep narrow stock wheel. My smallest 7mm socket still flares out to fit the wrench so it doesn't fit in deep enough. WHat brand wrench do you all use to fit the hole?
B6 - B6D - B64D - T5M - DEX410v5
joeld2llio is offline   Reply With Quote
Old 10-19-2014, 04:12 PM   #1008
trick25's Avatar
Trader Rating: 26 (100%+)
if you use one of those cheap rtr 4 way that come with a lot of kits, it will work. not the best solution but it works.
when you get more wheels get the de wheels so you can use any socket.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 10-19-2014, 04:46 PM   #1009
joeld2llio's Avatar
I forgot I had one of those. It worked great. Thank You!!!
Old 10-20-2014, 10:19 AM   #1010
trick25's Avatar
raced my dest again sat in a 2wd bucket class (3 st, 3 scb, 2 bug) took the TQ and the win. man i love this little truck. last outing(new to me track). qualed 2nd and took 2nd. IMO its the best car durango makes.
RM4 is really nice outdoors.
Old 10-20-2014, 05:02 PM   #1011
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
Im running mine MM4 inside, tight, high grip track. Raced mod truck Sat night, qualified 2nd in all 3 qualifiers, battled for 1st in the main a few times, ended up 2nd.
I went back to a full size pack in mine, with the 10.5t in it, I needed the extra weight to help tame it down a bit. Running it all the way to the rear, have pretty good steering, still a little nose heavy, but it is working pretty good all in all.
Jeepy2013 is offline   Reply With Quote
Old 10-20-2014, 09:26 PM   #1012
touringdriver's Avatar
Trader Rating: 15 (100%+)
Just mounted a Team Associated rc10 GT2 gas truck body to my Durango stadium truck. here's some pictures to get a general idea of the body post mods required to the body. fits nice everywhere else and doesn't run or hit anything.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 10-21-2014, 06:35 AM   #1013
Jeepy2013's Avatar
Good deal, I had a GT2 that I sold a little while back, that's how I knew it would fit the DEST210 fairly easy. I figured I would do the same if the time came where I couldn't get a TD body anymore.
Old 10-21-2014, 06:47 AM   #1014
trick25's Avatar
what did you have to mod? heat it around the front posts?
Old 10-21-2014, 07:09 AM   #1015
joeld2llio's Avatar
Ready to give my DEST210R its first run tomorrow night. Can't wait to give MM ST a try. If I like it I'm coming straight home and ordering a DESC210R also.
Old 10-21-2014, 07:28 AM   #1016
trick25's Avatar
I like the ST better than the SC. the sc never really felt planted to me. but I hope your results are better.
Old 10-21-2014, 07:48 AM   #1017
Trader Rating: 57 (100%+)
touringdriver: Get yourself a body reamer man!
Looks like the front of the body was heated and changed to me.
Nice. Very cool. I'd look through the For sale section here, Durango SC's can be had pretty cheap nowadays. If you want my thoughts on Durango, read back a few pages. Good luck!
shagino is offline   Reply With Quote
Old 10-21-2014, 08:39 AM   #1018
The front for the body post and heated a little on the rear for the body post. that was all needed.
Rock Chalk Jayhawks
Old 10-21-2014, 09:54 AM   #1019
i reamed the holes before heating the body, big mistake there on my part. ordered another body and this time i'll drill a small 1/8" hole and go from there after heating it up.
Rock Chalk Jayhawks
Old 10-21-2014, 07:01 PM   #1020
Jim85IROC's Avatar
Has anybody tried a body made for a Kyosho RT6 MM? I see that jconcepts has one that looks like it may fit. After seeing Touringdriver's post I started looking around and found that the RC10GT body fits the RT6, so an RT6 body may fit a DEST210.
Jim85IROC is offline   Reply With Quote
Team Durango DESC410R Thread KostaG Electric Off-Road 12303 10-17-2017 09:35 AM
