Like Tree2Likes
Old 06-11-2014, 10:45 PM   #901
Trader Rating: 138 (100%+)
Looking for a good setup for tight indoor hard packed clay.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 07-03-2014, 09:25 PM   #902
Devin's Avatar
I have a Dex and a DESC, what DEST specific parts are recommended to get for the pit box?
Devin is offline   Reply With Quote
Old 07-03-2014, 10:47 PM   #903
Trader Rating: 25 (100%+)
rear arms and inner hinge pins. Those are the only things that I broke on a regular...well I'm exagerating a tad...basis.
tfrankito is offline   Reply With Quote
Old 07-04-2014, 11:09 AM   #904
Devin's Avatar
Thanks Frank.
Hinge pins are 210 line generic and rear arms shared with the DESC. Things I like to hear
Your the second person to tell me to get rear arms. My SC has never broken one, ST must be harder on it / that bumper must be doing work.
Old 07-04-2014, 01:25 PM   #905
Thanks Frank.
Its the material that makes them frail when its cold. Boiling helps. I would go to Tower and get the new arms that just came in. Different plastic that is less susceptible to breakage.
Old 07-04-2014, 01:43 PM   #906
Thanks Frank.
I was using the old material. I have only broken 1 arm on my SCT but it was a huge hit. The stadium truck for some reason would break when I looked at it wrong. I was holding the car waist high and lost grip of it before my main. it fell on the tire at an angle and bent the hinge pin and broke the arm. Weird. I did notice I was using the kit arms from a year ago and they felt different then the new arms when I put them on.
Old 07-04-2014, 01:50 PM   #907
Devin's Avatar
OK,
Bought new arms with my order. Smeone else told me to get extra arms as well. You guys did at least $10 worth of arm twisting LOL.
Old 07-09-2014, 12:58 PM   #908
Devin's Avatar
What is the rule of thumb for shock weights? If 30w front and 25 rear has me really happy on the buggy, should I just keep it or does ST need to be a bit stiffer/lighter (in general).
If there is no general buggy to ST rule of thumb I'll just use my buggy shock set-up as a starting point.
Old 07-09-2014, 02:00 PM   #909
mcopeland65's Avatar
I would go with Cush starting setup and tweak from there. It is a good base setup to use. Just axe all of the tresrey, creme aftermarket stuff since you won't be using it.
mcopeland65 is offline   Reply With Quote
Old 07-09-2014, 02:18 PM   #910
trick25's Avatar
Trader Rating: 27 (100%+)
i broke more arms on sc than st. but almost all arms broke were outdoor when it was cold. they do not like cold much.
i really love my st. i really like associated and this truck drives better than my t4.1 with some of the 4.2 upgrades. my favorite st. only thing i dont like is the body is getting hard to get. going to try get a body made for associated to fit when this one goes.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 07-09-2014, 02:19 PM   #911
trick25's Avatar
i run thicker oils and 22t springs. but i run outdoors .
Old 07-09-2014, 02:50 PM   #912
No other body is a drop fit for it. Randy Pike had to run a Bulldog body with the back cut out to accommodate the rear shock towers.
Old 07-09-2014, 03:33 PM   #913
Send a message via Yahoo to nitro-rob Send a message via Skype™ to nitro-rob
I managed to get my hands on two bodies so I am lucky. I agree this ST handles very well, my friend chose between this and a 4.2, he bought both and he sold me the durango. He wants to get a durango after driving mine.
35/27.5 is what I am running.
nitro-rob is offline   Reply With Quote
Old 07-09-2014, 11:28 PM   #914
I think I ran cush's base set up. The rear I ended up with a 2x1.6 with pink sometimes red losi 22 springs. Only thing to keep it from slapping the 2x1.5 in the front felt good.
Old 07-10-2014, 07:40 AM   #915
Default Team Durango DEST210R kit purchase
I have been looking at purchasing this kit as I have never built a kit but always wanted to. My LHS is selling it for $140 so that made me start thinking about it. Can anyone give me some information on this truck? Thanks!
Leans is offline   Reply With Quote
Team Durango DESC410R Thread KostaG Electric Off-Road 12309 10-25-2017 11:00 PM
