Like Tree2Likes
Old 05-11-2014, 11:23 AM   #886
Send a message via Yahoo to nitro-rob Send a message via Skype™ to nitro-rob
I tried that yesterday, two .3mm kyosho shims and it didn't make a difference. I am starting to think my plates are warped.
nitro-rob is offline   Reply With Quote
Old 05-11-2014, 02:30 PM   #887
Kremzeek's Avatar
Originally Posted by Mind_Blower View Post
Try putting a washer on the slipper shaft before the first slipper plate. Between the first slipper plate and the bearing.
If you look at the manual for the DEX210v2, they have two shims in there now.
Kremzeek is offline   Reply With Quote
Old 05-12-2014, 12:59 AM   #888
Mind_Blower's Avatar
Send a message via AIM to Mind_Blower
Are you using a Durango spur gear? If not make sure the gear is not too thin in the middle. If it's too thin the center hub on the slipper plates may touch each other.
Erik Jensen
LiveRC.com
Mind_Blower is offline   Reply With Quote
Old 05-12-2014, 07:26 AM   #889
Trader Rating: 25 (100%+)
I just went with the avid slipper. Haven't had a problem since. My issue is I have to make sure I build the ball diff correctly or no matter how much I loosen the slipper my diff will bark. I have noticed that I have to run the ball diff tighter than with any of my other cars. With the avid I run 2 red pads and a white based on their info sheet. Although the diff feels tight it really isn't that much once it fully breaks in. There is a fine line between the perfect slipper setting and the diff barking.
tfrankito is offline   Reply With Quote
Old 05-12-2014, 07:53 AM   #890
trick25's Avatar
Trader Rating: 27 (100%+)
chalk up another win the dest. the truck will wipe the condescending smirk off a 4.2 owner in a hurry. and for half the price. love this little truck.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 05-12-2014, 12:37 PM   #891
Dstreelm's Avatar
Just called my local hobby shop about this truck and they said its been discontinued, was gonna get it for a friend, should I wait? is the new model incoming?
Dstreelm is offline   Reply With Quote
Old 05-14-2014, 07:05 PM   #892
Kremzeek's Avatar
Yep. That's why its selling for so little right now. Durango hasn't said anything about a DEST210V2 yet but I'd expect one is coming. As far as waiting, there really isn't a reason to do so. If the DEST210V2 is anything like the DEX210V2, you'll be able to upgrade your truck with the new parts.
Old 05-14-2014, 11:19 PM   #893
Does anyone happen to know the part numbers for the parts id need to make my rtr a mid motor. I dont have the manual that came w it.
Also what bodies will fit on it.....im kinda lookin for something w a cab forward look...
sikntired75 is offline   Reply With Quote
Old 05-15-2014, 12:43 AM   #894
Part #: TD320127 or type b #TD320270 and you will need one part from this TD320155 that extends to the motor guard but google the manual. There are a couple parts that get moved to the rear when you convert. Example the 2 long screws that go through the chassis and RF brace get moved to the rear.
Old 05-15-2014, 06:49 PM   #895
Kremzeek's Avatar
Does anyone have a good setup for a large, dirt track? I've been running my DEST210 on carpet until now and aside from switching it from mid to rear motor, I'm not sure where to really start.
Old 05-15-2014, 10:01 PM   #896
Trader Rating: 23 (100%+)
Originally Posted by trick25 View Post
color me impressed durango. i just built this kit and had first raceday on it. the four gear rear gives mega traction on loose dirt. i qualed second ahead of two guys i never qualed ahead of. was averaging over a second a lap faster and the truck was just plum faster than my wore out t4.1 ever was.
took 2nd out of 9.
i will be getting the 2wd sc this week while it on sale. t4.1 is gone and good chance the sc10 will be gone this week. i was struglling all day with it.
Was this mid or rear motor config ?
Thanks To My sponsors
Vertigo Performance
Arsenal RC
7075 RC.
Madera Hobby
acuratech is offline   Reply With Quote
Old 05-16-2014, 09:47 PM   #897
trick25's Avatar
i run both my 2wd sc and st in rear motor four gear.
Old 05-18-2014, 01:56 PM   #898
Kremzeek's Avatar
After seeing how little traction my SC10 had at the track yesterday, I'm thinking about running four gear as well.
Old 05-31-2014, 03:12 PM   #899
Panic09's Avatar
Hey guys, any info where I can get a new body for this truck?
"I was so far behind I thought I was first"
MIKES RC WORLD(r.i.p) | TACOMA RC RACEWAY | FOUR SEASONS RC RACEWAY(r.i.p) | ISLAND RACEWAY
Panic09 is offline   Reply With Quote
Old 05-31-2014, 06:55 PM   #900
303slowdown's Avatar
Trader Rating: 24 (100%+)
There's one on eBay. It isn't cheap though.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Team Durango DESC410R Thread KostaG Electric Off-Road 12309 10-25-2017 11:00 PM
