Like Tree2Likes
Old 03-26-2014, 09:19 AM   #826
Dan
Dan's Avatar
Trader Rating: 47 (100%+)
Wow, first Durango build. Plastic seems decent but there is so much slop and play in the suspension. I guess you get what you pay for...
Anyways, what is the recommended pinion for a small-medium sized track with 9.5 motor? (Will be running this MM4 motor setup)
Dan is offline   Reply With Quote
Old 03-26-2014, 12:11 PM   #827
Trader Rating: 38 (100%+)
Interested in this also, just picked up one of these kits and I will be running a viper 8.5. 20-22 may be a good place to start with it.
I wish I would have read some of this thread before picking it up. I had no idea about the front axle mod, to keep the wheel from seizing up.
Darkgenerals is offline   Reply With Quote
Old 03-26-2014, 09:23 PM   #828
Kremzeek's Avatar
You can use the included spacers to take out most of the slop.
Kremzeek is online now   Reply With Quote
Old 03-27-2014, 01:26 AM   #829
Dan
Dan's Avatar
Seems the 1mm spacers are too thick, particularly bad on the rear hub carrier hinge pins. Probably need something inbetween a .5mm to .7mm spacer. Either way, I'll just run it as is and see how it goes.
Old 03-31-2014, 10:37 AM   #830
First time building a Durango kit, I'm impressed with how bad the instructions are. Thankfully I've built kits before and have an idea on what I'm doing. I got lucky I think, and the kit I got came with the updated Type B parts, and the screws for the shock caps.
Any recommendations on a setup sheet for an indoor clay track?
Also I noticed the slop on the rear arms, I fixed that with using losi 22 2.0 aluminum bushings. I used a 1mm and a .5mm stacked together. This took out all the slop.
Old 04-16-2014, 02:29 PM   #831
awpldlto's Avatar
Default just bought a Team Durango Dest210
just ordered a dest210R kit from tower hobbies. http://www3.towerhobbies.com/cgi-bin...&I=LXCBXM&P=ML . it was $130 with free shipping after a $10 off coupon. as far as 2wd stadium trucks go did i make a good choice?
awpldlto is offline   Reply With Quote
Old 04-16-2014, 02:41 PM   #832
SUPERLOOPER's Avatar
Yes you did. Just watch this video on diff building. http://www.team-durango.com/in-the-p...rticle_id=4771
2017 Sponsors:
Team SOARSEIKI * AKA * Reds * Sanwa * Nitro Pro fuel * LFR * On point graphics * Xpert * M2C * Daytona RC paint
Brian Looper
SUPERLOOPER is offline   Reply With Quote
Old 04-16-2014, 02:44 PM   #833
awpldlto's Avatar
wasnt aware but this looks like it will be my first ball diff lol.
i just saw the price tag and figured why not. thanks for the heads up. im really excited to get back into 2wd.
Old 04-16-2014, 03:07 PM   #834
Brian C.'s Avatar
Hey guys does anyone have a good carpet setup? I got the car to the point where I would say its a good car, but I feel like it could be a lot better...
T&L BOYZ
Trains and Lanes Racing
Team Kyosho
Brian C. is offline   Reply With Quote
Old 04-16-2014, 03:19 PM   #835
I have always been a buggy man but a big races 1 class is not enough. I bought a dest 210 and have been enjoying it more than my buggy. I just use a buggy set up and go a little heavier on the oils and slightly smaller piston holes.
Fred
fredk is offline   Reply With Quote
Old 04-17-2014, 12:37 AM   #836
Suspended
haha is offline   Reply With Quote
Old 04-17-2014, 08:30 AM   #837
awpldlto's Avatar
how is the buggy version still so expensive? is nobody buying the stadium truck or something?
Old 04-17-2014, 08:35 AM   #838
trick25's Avatar
Trader Rating: 27 (100%+)
I have had t4.2(ish), team c, and have drove the rt5. this by far is my favority st I have drove and is my favorite car I race with. it just hooks outdoor in rm4.
well worth the 130 and more.
buggy has been revised. this has not. is why its cheaper. but this comes with type b parts from most places.
only thing I really don't care for is the body. seems the only body that exist for it is the stocker. but im going to find a way to mount me up a t4.2 body when the stock body dies.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 04-18-2014, 07:24 AM   #839
Kremzeek's Avatar
What does your current setup look like?
Old 04-18-2014, 10:04 AM   #840
Brian C.'s Avatar
I have 35wt oil all around, stock springs, and stood up the rear shock. other things i have tried don't seem to be working... I never changed spring though, their spring kit is expensive.
T&L BOYZ
Team Kyosho
Team Durango DESC410R Thread KostaG Electric Off-Road 12309 10-25-2017 11:00 PM
