Like Tree2Likes
Old 01-09-2014, 06:44 PM   #736
Could someone hook me up with a good set up for a high traction setup on a medium sized indoor track using slicks? I want to stay RM if at all possible.
cripplethreat is offline   Reply With Quote
Old 01-26-2014, 06:11 PM   #737
Konich's Avatar
Selling my DEST210 with every Tresrey Part Made for it. Ran for about 15 minutes. Comes with a new chassis and Tersrey prototype servo. $200 shipped. PM me for pictures if you're interested.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 01-26-2014, 07:54 PM   #738
Trader Rating: 36 (97%+)
I've got most of my kit built...I'm having trouble figuring out which inserts to use for the front and rear hubs...if someone could pm me or post on here which and why to use it would be greatly appreciated
Jake444 is offline   Reply With Quote
Old 01-26-2014, 07:59 PM   #739
Konich's Avatar
http://www.team-durango.com/in-the-p...rticle_id=4518
Old 01-26-2014, 08:01 PM   #740
this will help you most.. I didn't understand till I read this..
that link and
http://www.petitrc.com/setup/durango...goDEST210.html for what setup applies to your track.. there isn't many but it gives you a starting point.
Old 01-27-2014, 07:01 AM   #741
trick25's Avatar
Trader Rating: 25 (100%+)
is there a good baseline bigger outdoor track setup to start with?
my t4.1 was getting long in the tooth and I got the itch to build another kit so while tower had them for cheap with the coupon codes I snatched one up.
anyone drive this and AE and how do you compare the two?
4wd bug-D413, Blinky bug-XB2 17 CE 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 01-29-2014, 08:14 AM   #742
Trader Rating: 84 (100%+)
Default Chassis
Did they make a running change on this kit or do you have to buy the type b chassis
slyfinger1 is offline   Reply With Quote
Old 01-29-2014, 11:23 AM   #743
Trader Rating: 57 (100%+)
The new parts are included with kits and RTR's now. Did you just get one?
shagino is offline   Reply With Quote
Old 01-29-2014, 01:29 PM   #744
Yeah me and a couple of my friends just ordered some
Old 01-29-2014, 01:47 PM   #745
It'll probably come with the type B parts in the box. You'll need to out it on yourself if it's the RTR.
If not, call Hobbico.
Old 01-30-2014, 05:49 AM   #746
trick25's Avatar
i just got the kit and started building it. mine came with the type b suspension holders, parts, front bulkhead, chassis.
Only thing they messed up so far is the type b motor guard in my kit is for the SC not the ST. but as far as i can tell only difference is the sc has tabs to mount the rear bumper so im still going to use it.
from what i can tell so far(about 1/4 way done) is there was thought put into the design of this kit with wrenching on it in the future in mind.
so far i do not like how the front bumper looks cheesy.
also i did not know if you use the adjustable trailing front axle hubs it does not have bearings...not good....so i used the stock trailing arm hubs.
Old 01-30-2014, 06:00 AM   #747
Motor guard: I think the just threw the same ones in for the upgrades for all models rather than look DEX/DEST/DESC.
Trailing front axles: Those are for the DEX210 not the DEST210. All of the wheels use 15mm Hex. The trailing axles use bearing.
Old 01-30-2014, 06:12 AM   #748
trick25's Avatar
makes sense.
i was mistaken on the trailing arms.
how strong are the bellcranks/steering on this setup?
alo what worried me is that tiny little sevo link ends. are those breaking?
Old 01-30-2014, 06:54 AM   #749
makes sense.
I haven't heard of any issues with the bellcranks. I did upgrade to aluminum though. Just bling.
I popped off the steering link like one time. I don't think it's problematic
Old 01-30-2014, 07:26 AM   #750
anyone have or know where to get rear A arms? my buddy just broke his on dest210rtr and great planes/tower whatever is saying out of stock until April!
chuckb is offline   Reply With Quote
Team Durango DESC410R Thread KostaG Electric Off-Road 12281 08-18-2017 09:10 AM
