Team Durango DEST210R thread
#680
Who makes aluminum wheel hexes for the DEST210R?
Also, what's the max battery size (length, width & height) that will fit in the truck? I'm going to order some new 2s lipos, but I'm don't know the size of the battery tray. I haven't received my new DEST210R yet, if you're wondering why I'm asking for the battery tray size!!!
Thanks for your help!!!
#681
Don't know about the maximum sizes, but it is designed around 'race' packs
Length: 139mm
Width: 47mm
Height: 25.1mm
#682
I am a noob to 1/10 scale, ST, and Durango. I have a few questions regarding setup on my DEST210R.
Checking and setting ride height. Do I check it and set it the same as I do on my 1/8 scales? Install the battery, hold the truck about 12" above a table and drop it? At which points on the chassis do I measure?
Slipper clutch. Is there a "correct" way to set a slipper clutch, or a starting point? Is there a link on how to correctly set/adjust a slipper clutch?
A good basic setup. Does someone have, or can tell me where to find a good, basic setup for my DEST210R? I'm looking for a good, all around setup to start with.
I'm sure these questions have been asked a thousand times on this thread. If anyone can help me out, I would appreciate it very much!!
Thanks in advance for your help!
#683
- Yes and measure front and rear as you do w/ 1/8 lowest points.
- hold rear tires pull throttle it should only come off the ground a couple inches, if it doesn't pull up at all tighten slipper, if it flips right up or pulls a super high wheelie loosen it
- petitrc.com has several
- exotek makes the locking alum hex's as well as many other great parts for the desc210
#684
Yep, found, ordered, and installed the Exotek aluminum hexes! They do have a ton of nice stuff!
Thanks again for your help!!!
#686
I'm thinking about installing the gear diff in my DEST210R. I have read that it needs to be properly shimmed. I saw the assembly instructions on the Durango website. They show shimming the planetary gears, and putting the washer on the outdrives. Where else does it need shimming? When I install it into the tranny case?
Also, what's a good starting weight of oil to put in the gear diff? I read you should use black grease, but I also read that someone used 5k shock oil in their gear diff.
#687
I use 5k oil in mine, but it is something you need to play with, to find what you like.
#690
I rebuilt my ball diff and used acer carbide balls from tower and they are awesome! I also added new plates and made sure to put the curved side away from the balls, this gives a smoother surface to roll on. This diff is so quiet, very nice. I ordered 3 sets of balls to do 2 diffs.
